Question about Hotpoint Ultima WF860 Front Load Washer
My washer is stuck on f/o5 with water sstill init is a hotpoint ultima super silent
  • Anonymous Mar 21, 2014
    detergant left on clothes
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
There is a blockage. to get the water out put the end of the drain hose into a basin lower than the machine. you may have to shake it about a bit to get the water flowing.
you will need to check the filter or pump for foreign objects.
these may be at the front behind the kick plate or the rear behind the lower panel.
Posted on Feb 25, 2009
THANKS THAT WHAT I THOUGHT AS I HAD THIS PROBLEM BEFORE . JUST RANG HOTPOINT THOUGH THEY WANTED TO SEND SOMEONE OUT SAYING IT WAS A MOTOR PROBLEM.
THANKS YOU HAVE PUT MY MIND AT REST.
Posted on May 29, 2009
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi, i have washer / dryer "Hotpoint Ultima Super silent WD860" with an error code F13 when trying to use the dryer Please advice Thanks
Check the water supply, inlet valve, and hot & cold hose connections.
Got this piece of advice from their site..
Hope this helps.. :)
Jun 10, 2011 | Hotpoint Washing Machines
Can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN washing machine run off a cold fill only
The simple answer is yes, via a Y piece if it is a hot and cold fill model
The fitting is available from B&Q, or a plumbers merchants
Aug 13, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima super silent is occasionally showing the warning sign F11. Can you tell me what this sign means?
F11 means the pump cannot be activated.You may have a loose conection or faulty pump. For Hotpoint error codes go to http://www.selfix-uk.co.uk
Jul 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent wash wt 960
i rang the service engineer and they looked up the code, it was something to do with overheating, they are sending someone to fix it soon!
Dec 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
146 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
