Washing Machine won't stop filling and then won't stop emptying
My Simpson Esprit 750 washing machine will not stop filling up with water no matter where we turn the knob to. The only place on the dial that this does not happen is the stages where the machine normally pumps out the water - but on these cycles the machine will not stop emptying - HELP we are in a remote area of far north queensland and are currently cut off during the wet season - so if anyone can give me any ideas to get it up and running it would be greatly appreciated!!
  • sieverding_f Mar 01, 2009
    I have solved the problem with the fact that the washing machine would not stop filling - the small hose that goes on to the back of the water level knob had come off - now my remaining problem is that I have to turn the knob on the machine manually (it won't turn by itself) - If I need to order a part and replace it I can do that - but is there a stop gap measure that I can take as it usually takes a couple of weeks for freight to reach us - rivers and creeks permitting!!
I need a exploded diagram to get the water seal out as i am not sure which way to get it undone it is a simpson 750 esprit
Posted on Oct 20, 2009
    Scholar:
  • 106 Answers
Does your machine fill with water even if the machine is off? In this case your inlet valve at top of machine is defective & can be easily replaced (will tell u where to get spares, if your dealer cannot) by yourself.
If water does not stop, after filling machine at a low level(is this a front loader?) and is flowing away - check your exit pipe, it has to have a certain height (approx 3 feet) up before going down to your drain pipe.
Posted on Feb 27, 2009
  • fixer444 Feb 27, 2009
    RepairClinic.com (which is good)
    espares.co.uk
    AppliancePartsPros.com
    Try these sites.
2 Suggested Answers
SOURCE: Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Posted on Jan 23, 2010
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
Simpson washing machine will not fill with water. Epsrite 750. Hoses are fine, water pressure is fine. Just a dribble goes into the tub
Most hoses have a filter/strainer at the faucet end. This can get clogged. Remove from water source, check and clean.
Sep 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
faulty control board or timer
Nov 19, 2017 | Washing Machines
Water level
Probable causes:
Faulty water inlet valve - unplug washer, if water continues to fill
replace the valve.
Water level switch, hose or dome faulty - service the assembly.
Timer faulty - unplug washer, if water stops filling test timer.
Regards,
Dennis
Aug 22, 2014 | Simpson Esprit 750 Top Load 7.5kg
Water drain out immediately while filling the washing machine
you should check 2 things the drain pipe should be higher than the drum or there is some dirt in the thin pipe of the pressure switch try to blow air in it in order to clean it
Feb 10, 2014 | Simpson Esprit 750 Top Load 7.5kg
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Nov 15, 2009 | Washing Machines
Washing Machines Logo
933 people viewed this question
Top Washing Machines Experts
