Question about Sony VAIO PCG-Z1WAMP1 Notebook
Hi.. i excuse me for my bad english, but i hope you can understand what i mean. I have an Sony Vaio PCG-Z1XMp with a MBX-71 Mainboard integrated, yesterday the laptop don't start up. so i opened the laptop to see what it can behave. i have the problem, that i have no power to battery, 12V aren't there, i haven't also the 3.3V Digital Line for the run impuls that must became from the power button, i testet all the fusibles and i haven't found any where has a problem. have you any other ideas and can i have a service manual from that mainboard? Best reguards De Nola Luca luca.denola@johnlay.ch
Motherboard for sony vaio laptop model No.PCG 71315L
This may help;
http://www.ebay.co.uk/itm/PCG-71211N-Sony-motherboard-For-71315L-71211W-MBX-223-/151284352192?pt=UK_CE_GPS_Accessories_Software_ET&hash=item23394004c0
Sep 11, 2014 | Computers & Internet
Sony VAIO PCG-Z1XMP Notebook DRIVER DOWNLOAD FREE
you can download the driver for Vaio z1xmp from here.
Hope this helps, thanks for using fixya.
Nov 08, 2011 | Sony VAIO Notebook
Im looking for a manuel for a vario pcg-141c
I think the PCG-141C may also be identified as PCG-C1VE - this reference would normally be on a label somewhere on the screen surround, rather than on the underside of the unit.
An English language manual can be obtained from the following URL:
ftp://ftp.vaio-link.com/pub/Manuals/Notebooks/C1/C1VE/C1VE_H_UK.pdf
The manuals page, if you require a different language or access to any other downloads for this machine, is http://support.vaio.sony.eu/computing/vaio/documentation/manuals/index.aspx?m=PCG-C1VE&l=en_GB
I hope this helps.
Jul 25, 2011 | Sony Computers & Internet
Sony Vaio Laptop PCG 9U1M
PCG-K415B is the correct model number the label is possibly the service tage or something.
Here are the specifications of your laptop
  • Intel Celeron D Processor 345 3.06GHz / 533MHz FSB
  • 512MB DDR SDRAM - Low cost double memory Offer - call for details
  • 40GB Hard Drive
  • DVD Dual Layer Drive - To read DVDs and CDs and write CDs, DVD+, DVD- and large Dual Layer DVD
  • 15.4" XGA xblacklogo.jpg Widescreen TFT Screen
  • ATI Mobility Radeon 345M 64MB shared graphics
  • Integrated wireless 802.11b/g LAN - Call for advice on Wireless networking
  • Integrated 3-in-1 card reader –Memory Stick, Memory Stick Pro, Memory Stick Duo
  • Operating System: Windows XP Home Edition
  • Includes Sony Software Bundle
My guess is that the laptop is around 1 or 1and half year old as the celeron 3.06GHz is a relatively new processor.
May 26, 2009 | Sony VAIO VGN-AR230G Notebook
My sony vaio vgn-ar61 does not detect the motion eye camera, when i go into device manager then into scanners and cameras there is only a xerox scanner being detected i have no idea were this has come from...
Hi axal49,
I seem to understand your problem. I have a Sony VAIO laptop and I might know how.... do you have VAIO Recovery Center on your PC? If you do then go to recovery center and find Reinstall Programs or Drivers.
If not then click here:
http://esupport.sony.com/perl/select-system.pl
May 13, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Memory Problems
you may have a compatible issue with the ram, your board bois may not support that manufavtures brand or coding of the chip set you are running. have some else try some other ram from another manufacture.
rod
Feb 11, 2009 | Sony MBX-49 ASSY Motherboard
Pcg k45 sony vaio
chek the adapter and female power soket on laptop. if they are ok, clear the bios by reset bottom(there is a small hole under laptop) or removing small battery on mainboard.if the problem not solved ,have to change the mainboard.
Aug 16, 2008 | Sony VAIO K45 Notebook
Sony pcg 9h4l motherboard issue
Try to power off unit and remove the battery. Then press and hold power button for 30seconds.Put the battery back and turn it on. If it turns on turn it back off again and remove the battery. Connect your VAIO using the AC adapter only. If this will not resolve your issue you can check this with SONY or any certified service center.
May 23, 2008 | Sony MBX-49 ASSY Motherboard
Part number for PCG GRZ600P vaio motherboard
This uses the same motherboard as grz 610/630/660. The motherboard is MBX-75
Mar 18, 2008 | Sony VAIO GRZ660 Notebook
Sony VAIO PCG-Z1WAMP1 Notebook Logo
365 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
