Outside A/c unit stays on for 1 min then off.
Outside unit of my a/c comes on for a minute then goes off. Inside unit seems to start normally but after about 5 mins the led lights start blinking then only one light (left one) keeps blinking.
    Problem Solver:
  • 5 Answers
Check comp capacitor if its ok check the overload protector if its ok then the compressor have to be changed
Posted on Feb 24, 2009
CD player works but start delays from 5 minutes to 20 minutes. What could cause that?
Dust inside the cd player could be causing problems.
You need to try playing a cleaning cd and follow the instructions that come with it. You can also spray compressed air to clean out the cd portion of the stereo. You can also try unplugging the unit for 20 minutes and then plug it back in. Make sure your cds are clean and not too scratched up. If the unit is under a year old it may still be under warranty. If this does not resolve the issue you may have to have the unit professionally repaired. If the unit is not worth repairing you may need to buy another unit.
Nov 02, 2015 | JVC UX-T3 Shelf System
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
Inside unit turns on, outside doesn't
Could be a wiring problem or a lack of refrigerant. All you can do is professionally have the unit checked and serviced.
Hope this helps I take the time to answer your question so please rate me
May 22, 2010 | Mitsubishi MSZ-A15NA Split System Air...
Goodman package- no heat below 30 degrees outside
I believe the unit you are describing is a heat pump. Heat pump are great when the temperature isn't below 30 With low ambient temps. outside it is much more efficient and comfortable to run aux. electric heat from the heat pump.
Jan 03, 2010 | Goodman PHKJ048-1 Air Conditioner
I have a Goodman CK36-1a outside unit. It will not kick on.
If you have power to the unit and the contactor is pulling in ( low voltage side ) and neither compressor nor the fan comes on it could be 1 of 2 problems first check the wiring a mouse may have chewed through one of them, or 2nd your capactor is bad.
Cozy cool home comforts
Jul 05, 2009 | Heating & Cooling
Mobile caught in rain storm!
It seems that there are some water traces inside. Use your hair dryer without heat on it for a few minutes and try again. repeat the process a few times. Keep spending ten pounds as the last resort. And in future remember the hair dryer whenever you bathe your mobile. Also remove the battery soonest possible.
Jul 03, 2009 | Nokia 6220 classic Smartphone
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
