May be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: diyobd2.fr
SOURCE: 94 Jeep Grand Cherokee is hard to start. If I turn
Has any one soled this yet???????? Because I have the the same prob. but mine is only when it is could out blow 65 it will start but I have to keep my foot on the gas like a carb with no choke
SOURCE: 1998 Jeep grand Cheroke hard cranking, sputtering, rough idling
In READING what you wrote, it appears that your car is difficult to start and pretty much is rough while running....It also appears that your are randomly replacing parts...How did you verify that the parts your have replaced had failed? I suggest you get a basic manual like chiltons or haynes as well as a decent digital volt/ohmeter, then do some testing. Pay close attention to map sensor test and manifold air temp. Having a good fuel pump does not insure that your injectors are clean enough to deliver a good spray pattern This will not show up on any test...you need to actually look at them. There are other items to look at but I think you will likely find your problem in what i mentioned. (you already checked for vacuum leaks, right?)
SOURCE: I have a 1994 jeep grand cherokee laredo its
The computer is releasing to much gas into the chamber. It something you'll have to get the computer to re-learn, or update it at the dealership. Only someone/company with a Tech2 can do as it connects to your cars computer (ECM) and once in there you can select the option to watch/measure or less / plus the fuel consumption.
SOURCE: My 1996 Jeep Cherokee Sport dies or will not start when hot.
Sounds like the ignition coil is getting bad.
