Question about HP C6280 All-in-One Printer
Paper jam in hp c6280
Paper is jammed and can not find any button to release it. the booklet that came with the machine is for c6200 series, but picture in the trouble shooting section is different from our machine.it says to press the tabs on the left and right side of the two sided printing accessary, ours does not apear to have any tabs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 544 Answers
There is no paper jam but printer keeps clicking to pull paper thru then goes to paper jam. How do i fix it
It may have a paper fragment holding the paper edge exit sensor just above the main drive roller bar. You will probably need to remove the casing to get to it, although it may be possible to see it from the back once you remove the back panel.
Sep 05, 2016 | HP C6280 Photosmart All-in-One Printer...
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Hello, my printer had several paper jams... Now, once the paper jams are gone, it skips and then shoots the paper out. I can not align the paper or calibrate it.
- Press and hold the "*" key.
- Press the "#" key and release both keys.
- Display should say "Enter Special Key Combo" then release the keys and press "1", "2" and "3" buttons in sequence.
- then you will get few options, now look for an option that says "System Menu or System Information" using arrows keys.
- Press "OK" on it & now look for "semi full re-set and press ok".
- Now printer will turn off and will turn on automatically after few seconds.
- Now printer will align it automaticaly.
Feb 25, 2011 | HP Photosmart C6280 Printer
C6280/paper jam
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | HP Photosmart C6280 Printer
My HP C6280 says that there is a paper jam. I
dear sir this problem is your printer macanical
please open printer cover and chack clought unit spring tension
Aug 12, 2009 | HP Photosmart C6280 Printer
HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
Please try this to clear the paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | HP Photosmart C6280 Printer
Paper jam in HP Photosmart C 6280
Have you tried removing the back panel. Click on the link for pictures but it is the easiest way to access the paper in the printer when jammed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01257110&cc=us&lc=en&dlc=en&product=3194498
Jan 15, 2009 | HP Photosmart C6280 Printer
My HP Photosmart C6200 All IN ONE serial # MY7AJH63BB, will not print photos coming from my Mini Mac computer on to the photo paper in the photo paper tray. It will only print onto 8x11 paper sheet. I...
None of the buttons on my 3 in 1 photosmart c6280 work but I can use to HP solution to get prints ,scan , and copy. Can not turn off or clear '! "button with out unpluging
THANKS
Nov 29, 2008 | HP Office Equipment & Supplies
HP C6280 All-in-One Printer Logo
181 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
