Question about Ovens
The gas oven I found was built in a weird way. Is it ok to use?
I'm living in a rented apt, and about to move to a new one. The apt I'm renting has a gas stove that has a pipe that brings the gas directly under each of the 4 burners, i.e. the gas travels right up into the small metal bowl that sits under the pot that I put onto the burner.
A few days ago I found near my home a sauter oven built in 1994 that looks rusted and was therefore thrown out by a neighbor. I checked it carefully and it works fine, so I'd like to take it to my new apt when I move, since I can't take the oven I have.
But I noticed that in the oven I found, the gas does not go directly to the small metal bowl. Instead, there is about a one inch gap between where the gas leaves the pipe and that bowl. I wonder why Sauter would build an oven that way. Wouldn't it waste gas, since can't we assume that not all the gas that leaves the pipe will rise in a perfectly vertical fashion and go under the burner. Surely some gas will escape into the air, something which not only wastes money but is also unhealthy to breathe. Does anyone have any thoughts on this?
Thank you very much
  • shlo77 Feb 24, 2009
    It comes with an igniter, so I won't need to get close to the gas when I light it. As for the gas escaping, I just had a thought: I can put a metal tube between the bottom of the bowl and the spot where the gas leaves, thereby bringing all the gas to the bowl. I can even create such a tube with aluminum foil.
    A new oven is over $600 here. I just want some helpful feedback on my situation, before I go ahead and do it.
    By the way, it would have been very easy for Sauter to bring the gas to the bowl, so there must be some reason why they created that air gap. I'd love to know what it is, or to have ideas about how to create the tube to bring the gas to the bowl.
    Thank you
    There is no lining to change. The bowl has a hole under it, and about an inch directly below that hole, sits the hole where the gas escapes from. I need a simple way to bring the gas to the hole, or else to understand why the oven was made this way, since for a few more dollars Sauter could have brought the gas directly to the burner. 1994 is not that long ago. I don't understand why the oven was made this way.
    Genius:
  • 1,550 Answers
Yes you are right it wastes money as well as health related problem occurs due to this .
So better call technican to change the lining to minimize the loss .
Posted on Feb 24, 2009
  • Ovens Master
  • 13,433 Answers
Hey,
Just read your problem and I don't think its a good idea to use that, the gas indeed can get out from other places than its supposed to and if you have to light the gas yourself, there might be a small chance of burning yourself a little, especially if the gas is left open.
I would personally find another.
Thanks,
Ekse
  • Ekse Feb 24, 2009
    Does the oven have a model number or do you see any details text codes numbers etc on it?
Any ideas how to fix a GE wall oven that is NOT self-cleaning, but sometimes shuts off and the locked door light flashes and will not let me turn on the oven again for a while? I guess it needs to co
sounds like one of the safety features is bad
it might be as easy as replacing one part (could be anywhere from $5 to $95 though some can be more)
but i don't have even a parts list let alone the schematics to be more helpful.
one thing to consider when deciding fix or buy new is the age of unit
likely that more efficient units are available
if you are renting the landlord should be informed of the faulty unit connected to the gas and electricity (code words for likely a major safety hazard)
if you own the new unit likely will save you money since it will be more energy effecient
May 23, 2014 | GE Ovens
Help! I am renting an apt (and the owner is overseas) and the oven/range which came with it is an older Caloric Prestige series (gas range and oven) with self-clean feature. It has been cleaned so often...
Hello!
can you find information (sticker / label)in the body of the oven. It will be easy giving you information if you can provide the brand and model number of the oven.
Please post back!
Apr 10, 2011 | Ovens
When turning on the oven it refuses to heat! The inside light and fan both come on however the oven does not get hot. This problem occurred overnight it was fine one day and went on strike the next. I...
If the fan is working o/k, then it is going to be the oven element that is faulty. This is located behind a removeable cover at the rear of the oven compartment.
Oct 27, 2010 | Smeg SE210X/1 Stainless Steel Electric...
USER MANUAL FOR WHIRLPOOL OVEN AKZ151
You can fin it here
http://kitchen.manualsonline.com/ex/thread/view/idThread/2080872
Sep 22, 2009 | Ovens
Self clean for 4 hours -- do i need to leave my apt?
The first time you do a self clean it does smell weird and you do not need to do it for 4 hours change the setting to 2 or three hours. This uses allot of ellectricity to do the cleaning. I usually just use a oven clenaing product for light cleanup. If you have a pie that has spilled over or something then it works great. The Smell is a bit of ash and smoke from all the things that you are incinerating inside your oven.
Cheers
Al
Sep 11, 2009 | Bosch Ovens
RENTING CONDO WITH SELF-CLEAN WHIRLPOOL OVEN RF376PXDQ
If this a relatively new oven it show have a self cleaning identification on the control area or panel. Just close & select self cleaning option should take about 1 1/2 - 3 Hours
Mar 25, 2009 | Ovens
Gas to stay on
hi. thanks for the question. the part you need to replace is the thermocouple on the gas valve. replace that part. thanks the appliance doc
Oct 05, 2008 | Fagor 5HA-196 X Single Oven
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
My oven wont come on
try this if one of the dials is pushed in turn the other around till it pops out
Feb 13, 2008 | Ovens
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Oven Expert? Answer questions, earn points and help others
