Question about Symbol MC9090-G RFID Handheld Barcode Scanner
The equivalent of the
We are trying to find the equivalent of the button on our MC9090-G handscanner (53 function keys).
How to turn up volume on handheld?
It is best to contact Motorola Solutions.
http://www.motorolasolutions.com/support
Mark
Motorola Mobility Support
Aug 18, 2014 | Motorola MC9190-G Handheld Mobile Computer
I need e-toll contact number
Bongiwe
Contact Motorola Solutions. portal motorolasolutions com
Mark
Aug 15, 2014 | Motorola MC9090-K DEMO KIT CONTAINS UNIT...
Function keys on MC9090
hi,
Sound like you need to look at your Keyboard mapping files, easiest way to fix this is to use Motorola System Configuration Manager - Downloadable from the Motorola website.
If the unit need to be restored to factory defaults, than a fast way is to run the Clean boot files from the SD Card also downloadable via the Motorola site - search for 'MC9090 Clean boot'
Mar 04, 2013 | Symbol MC9090-G Barcode Scanner
When I press the keys on my MC9090 they give the wrong output.
The Motorola MC9090 can have different keypads attached. If you do change the keypad for any reason for example go from a 53 key to 43 key layout the terminals must be cold booted.
To cold boot an MC9090 running Windows Mobile 5. Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the device is still not giving the correct key output it may have a faulty keypad.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 11, 2012 | Zebra MC9090-G Barcode Scanner
What is the F3 key on the mc9090
second function key only - you can programme the key
Sep 20, 2011 | Symbol MC9090-G Barcode Scanner
How to configure Function keys on MC9090 from ITS service
my problem is in the configuration of symbol MC9090 in comunication with sap when send function Key ( F5) .
Question .
What the value that the SAP waiting this process?
May 17, 2010 | Symbol MC9090-G RFID Handheld Barcode...
Not ABLE to switch on MC9090. tried replacing the battery . Held the power button for 2 mins . nothing is working. Is there any key combination to start the reader ? please help.
I know it may be a little late now since you're question was a couple months ago, but I have had this problem with some 9090's before too where a warm boot (holding the power button down) will not bring them up, but a cold boot always does (unless of course it truly is defective - that's not usually the case though).
To do a cold boot, pop the battery out part of the way until it "catches" (you'll know what I mean if you have an MC9090 and try it). Then hold down the trigger and the power button simultaneously while pushing in the battery all the way. Once the battery has been pushed in, release the power button and the trigger.
This should cause the MC9090 to boot up fine. Make sure you release the trigger after doing the steps above. Sometimes people don't do that, and this causes the MC9090 to go into an infinite warm boot where it just continuously reboots over and over. The only way to get out of it is to cold boot again, but this time release the trigger in time.
Thanks,
Brad Radaker
Radicomm (makers of QuickTalk - push-to-talk over WLAN for the MC9090)
www.radicomm.com
Mar 02, 2009 | Zebra Symbol Technologies MC909X-G Series...
My MC9090-G scanner is stuck in boot mode. I've tried a cold boot and warm boot and nothing works.
Actually if it is continuously rebooting, it is usually because someone was holding down the trigger through a cold boot process. That's what puts it into this continuous reboot loop. To get out of it do a cold boot again (pop the battery part of the way out, hold down the power button and trigger simultaneously, and then push the battery back in while the power button and trigger are still down). But as soon as you push in the battery to the point where you hear it click, release the trigger. If you hold it in too long, the unit will start continuously rebooting.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk - push-to-talk for the MC9090)
www.radicomm.com
Nov 21, 2008 | Symbol MC9090-G LORAX MONO 64/ 64MB 53 VT...
Symbol MC9090-G RFID Handheld Barcode Scanner Logo
201 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
