Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 paper jam
Hi, i have a Canon Pixma MP210 printer. 2 sheets of paper were jammed in it and since removing them whenever i print it makes a clunking sound and there are lines through the print always in certain places. What could the problem be? and is it worth fixing or shud i just get a new one?
  • 46 Answers
Try to get in touch with canon service centre in your area and get it fixed it will be a small problem
Posted on Feb 24, 2009
Paper feed problem
Hi
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 Paper Jam
A common issue is moisture. As the relative humidity changes, the paper will absorb some of the excess moisture. (Ink jets don't get as hot as other printers; but they do have temperature changes during operation.)
Unfortunately, the only solution that I have ever found is to use paper from a just opened package. Try to keep only enough paper in the printer for a short duration of printing (1-2 weeks). Keep the rest of an open package of paper somewhere else where the temperature and humidity stays fairly constant.
I hope this helps.
Feb 26, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper wont load and print
Open the rear of the printer...this is easy...as there is an access door....check to see if you have paper jam...
if there is remove and retry
keep me posted
Cheers!
Nov 13, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
PAPER JAMMED
If you are unable to remove the jammed paper from inside the Automatic Sheet Feeder (ASF) then it is necessary to remove the printer top cover. The ASF is then easily removed by removing three screws, and any jammed paper removed from it.
If you require assistance in how to remove the top cover, please post a new comment to this effect.
Aug 02, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
415 people viewed this question
old marine
old marine
