Question about Motorola Mobility RAZR V3i Cellular Phone
I can`t turn on my motorola v3i bluetooth..it says bluetooth power failed.
  • vijayramloch Feb 25, 2009
    i can't turn on my motorola v3i bluetooth..it says"
  • Joe
    Joe May 11, 2010
    Can you be more descriptive. Is the power not coming on?...or is it not connecting to your phone?
Its says everytime power fail
Posted on Mar 10, 2009
I wont pick gratis
Posted on Mar 07, 2009
V3i how to instal game&themes
well.........you can download the games, themes from the internet and send them into your mobile
For games check these site
http://www.gamemobile.co.uk/motorola_v3i_games.htm
http://www.mobilerated.com/motorola-razr-v3i-games.html
For themes and apps
http://www.mobileheart.com/cell-phone-themes/819-Motorola-RAZR-V3i-Themes.aspx
http://gallery.mobile9.com/c/motorola-razr-v3i-themes_289/1/
http://www.mobilerated.com/motorola-razr-v3i-home.html
http://www.mobileheart.com/cell-phone-softwares/819-Motorola-RAZR-V3i-Software.aspx
send the applications via bluetooth or usb wire
Aug 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
V3i
hi..ur motorola v3i is defaulted with 7 to 10 hrs of battery life only...o save more power...
  • Keep the brightness on the screen to a minimum. You can also adjust how long the backlight stays on without input from the user.
  • Turn off the Bluetooth when not in use. Bluetooth is a big battery draw.
  • Disable incoming beams so that the phone isn't constantly "searching" for infrared partners.
  • Completely close non-essential programs. When you run an application, it does not shut down completely when you "close" it. It is simply minimized. Go into the Settings to completely shut down any programs you are no longer using
  • also u cud get a car charger so that u cud be sure not to run out of juice..
    Thanks for using Fixya
    Aug 22, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Motorola v3i
    are you tring to sync by usb? sometimes depending on your computer you might need additional hardware.
    your best bet is just go and by a bluetooth doogle for 4.99 and sync via bluetooth. or go and buy a verision of moto sync. 39.99 at the motorola webiste.
    for the doogle go to cellphoneshop.net there cheap.
    sincerly
    http://wowwireless.ecrater.com
    Aug 08, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Bluetooth won't power on
    when you power on bluetooth and do nothing within 60 seconds it does not work and then you will have to apply "find me"
    May 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Motorola V3i Bluetooth problem
    hello h ru i am arsalan from pkistan hacking master plz give me any sms viurs code plz send me is my email arsaan_hackar1@yahoo.com
    Jan 19, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Bluetooth connectivity
    Bluetooth doesn't shut off on its own unless you turn off your phone. In the bluetooth options, you should be able to select "Turning Bluetooth On", "Turning Bluetooth Off", or "Using Discovery Mode (60 seconds)." Discovery Mode, which I believe is what your using, is only used when connecting to another device. My question for you is, what kind of device are you trying to connect to?
    Sep 05, 2007 | Motorola Mobility RAZR V3i Cellular Phone
    Bluetooth failure
    pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time then start file copy
    Jul 19, 2007 | Motorola Mobility RAZR V3i Cellular Phone
    Motorola Mobility RAZR V3i Cellular Phone Logo
    164 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    D. E. Hev
    Lawrence Oravetz
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
