Question about Lexmark X2650 All-In-One InkJet Printer
Lexmark printer x 2650 won't print.
I bought this printer a month ago. Usually it's ok and i can print. But today it won't. The A4 paper seem to be stuck. When i press the install paper button, it doesn't work. The A4 paper doesn't want to go in.
  • jono9784 Feb 28, 2009
    I've had this printer for a few months, and bought soem new artrdiges today likewise, and suddenly the feeder wil lfeed, but won't go in properl, it tries to feed in diagonly, which scrintches all the paper up. Any solutions that are at least soemwhat achieveable and affordable, this is the second lexmark i've had in the past year, these things shouldn't just die.
  • 46 Answers
U need to remove the stuck paper turn off the printer and start again
Posted on Feb 24, 2009
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
When trying to print the paper won't feed through. It will on the left side (looking at the front of the printer) but won't on the right preventing it to print. I just bought and replaced both...
There could be something blocking the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder. Make sure there are foreign objects or debris that could cause this problem.
May 13, 2011 | Lexmark X4650 InkJet Printer
The exclamation point light on our Lexmark printer E260dn continues to light up. Each time, we have to open the panel that covers the toner area and close that panel. Then our print job continues . . ....
you have to check paper settings (letter, A4..etc)
For examle - > if you trying to print A4 but printer expecting Letter this error will occur...
If you using Windows XP - .> click start button, then click on Printer and Faxes, select your printer and then click right mouse button on him, select Properties, then click Printing Preferences, now click on tab Paper/Quality and select right paper format...
Rate me if i'm usefull :)
Jan 14, 2011 | Lexmark E234 Laser Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MP 270 spooler problems paper jam problems scanning probs
I have had problems with this printer, too. See my Amazon review here:
http://www.amazon.co.uk/product-reviews/B002LVUKL0/ref=cm_cr_dp_hist_1?ie=UTF8&showViewpoints=0&filterBy=addOneStar
(Mine is the second one down).
The Canon MP270 does seem to have a few problems. It's not one of Canon's finest products, to say the least. It seems to be getting a reputation for problems, problems...
I gave up and bought a HP Deskjet printer instead. I know that's not a fix, but I found it was the best solution!
May 24, 2010 | Canon PIXMA MP240 All-In-One InkJet...
I have an HP 4V laserjet printer. It was printing fine until today. Both trays are full but it wont print. Form feed light is on, LC load letter message is flashing.
This is looking for Letter Sized Paper and presumably nit A$ that you normally use. This is usually caused by printing US documents and not resetting the paper size in the application before printing as the paper size will be embedded in the document in its original format.
Simply select the whole document and then reset the paper size to A4. You may need to check the document for lost images and tables but generally the text should be OK. Also the index and table of contents will also be affected as you will presumably have more A4 pages in the reformatted document that in the original.
Sep 21, 2009 | HP Office Equipment & Supplies
It will print OK but the paper feed stops when using it as a copier
Make sure the paper size selected for when you copy is the same as you normally use. For example. If its set to A4 and you usually use something smaller it will recognise the size and it wont print.
Jul 07, 2009 | Lexmark X4650 InkJet Printer
Lexmark 5400 series printer
It seems you have some piece of paper in the carrier.
Could be just a very small piece somewhere in it... remove the cover and take a very close look. Check all rolls if they are loose or if something is locking them.
Jul 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
Pohot paper jamming in Brother DCP-115C printer
This is a common error of this printertype. Please use only paper of max. 220g. There is no problem reported with that.
Jan 14, 2007 | Brother DCP-110C All-In-One InkJet Printer
Lexmark X2650 All-In-One InkJet Printer Logo
127 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
