Question about Intel D845GVSR Motherboard
Hai all when switch on my pc, a message "A disk read error occured please press ctrl+Alt+Delete" being displayed, what should I do? even I press ctrl+Alt+Del,again same message, I have tried to format, but after o.s files copied ,while restarting same message being displayed
  • Intel Master
  • 2,382 Answers
Your boot sequence is changed, put the hard disk to first boot in setup menu, or the hard disk gone bad.
Posted on Feb 24, 2009
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
Disk read error occured
If not give it a go and do a repair if needed again!
1- You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
2 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
3- or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!!
Mar 26, 2009 | Dell Inspiron 1525 Laptop Jet Black
A disk read error has occured press CTRL-ALT-DELETE to restart.
check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
A disk read error occurred, press ctrl-alt-+delete to restart
Hello Sir
I am afraid that the hard drive is corrupt. It needs to be reformatted and reinstalled. There is also a good possibility that the hard drive will need to be replaced I am afraid. To make sure ask the technician or who will attend to it to disconnect the hard drive from your laptop. Plug it in an enclosure and copy all of its contents before reformatting. IF IT DOES WORK then don't let them trick you that it needs to be changed as it is just a case of corrupt files and a reformat / reinstall will do it good. In this manner you hit 2 birds with one stone and you get things back up and running :)
Hope that this solution helped you :)
Best Regards
Alx :)
Jan 07, 2009 | Sony VAIO VGN-N130G/W Notebook
when upower up thecomputer enter in bios setup press del or F2 or F1 to neter in bios setup when u power up.
thenr eset bios defaults settings.
then check your hardiskk is deteted or not.
if sata is enabled then disable then press F10 to save settings.
Jan 07, 2009 | Sony VAIO VGN-FS640W Notebook
More than likely you have a hard drive failing/failure.
You should have it looked at if you are not "comfortable" doing it yourself.
Hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Apr 23, 2008 | IBM ThinkPad T43 Notebook
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Intel D845GVSR Motherboard Logo
112 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
