Question about Samsung D880 Cellular Phone
Mobil is shut down as it drenched with water
Mobil is shut downed as it was wet due to water i want your suggestion
    Problem Solver:
  • 5 Answers
If you can dis assemble including flex and lcd then do it .and clean the mainboar with laquer thiner with toothbrush it will dry in afew minutes
Posted on Mar 04, 2009
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My htc wildfire was placed on wet clothes by mistake. when i turn my camera on the phone shuts down. there are water spots on the camera lens. what should i do now? :(
Switch off your mobile and keep it to dry. You can go to HTC service station to remove that water spots from camera lens and from other parts.
May 24, 2011 | HTC Wildfire Cell Phone
My cellular phone got wet
As the mobile is wet the circuit board inside the mobile will be fully wet.Due to this the connections between the circuits get connected (short circuited) and the mobile may behave in such a manner that it should not behave.
NEVER put the wet mobile in charger even though it is dry and working properly.There may be water logs present in the mobile circuit which may be dangerous to the person who is using the mobile.It may lead to electric shock.
Take the mobile to the authorized dealer of your make and they will remove the water log from the mobile circuit board and it will be fine .I recommend you not to do this by yourself.
Thank You
Aug 17, 2010 | Nokia 6300 Cellular Phone
Fridge water-dispenser not working, after shutting down water line from basement, due to plumbing repairs elsewhere. It was working fine the morning of, and after shutting down the water for about 2-3...
Water in unit has possibly iced up. Turn water supply off again and read you user manual on haw to defrost/deice unit. Furthermore ensure water supple is actally pressurised. Backflush the supply if possible.
Mar 24, 2010 | Refrigerators
I just got a malber 1000 washer/dryer. Can it be used as a dryer only?
NO THIS UNIT USES CONDENSED DRYING AND WILL WET THE CLOTHES BEFORE IT EVEN TURNS ON THE HEATER. BASICALLY YOUR COMBO USES STEAM CIRCULATION THRU YOUR CLOTHES. AS THE SMALL WATER PARTICLES IN THE STEAM MOVE THRU YOUR CLOTHES IT COMBINES WITH SMALL WATER PARTICALS IN THE CLOTHES(THINK OF 2 WATER DROPS COMBINING ON YOUR WINDSHEILD AND HOW THEY ABSORB TOGETHER) WHICH RISE TO THE TOP OF THE TUB AND COLLECT INTO WATER AGAIN. THEY THEN ROLL DOWN THE SIDES OF THE TUB AND COLLECT AGAIN AT THE BOTTOM TO BE PUMPED OUT. BEFORE THIS PROCESS EVEN STARTS THE UNIT WILL ACTUALLY ADD WATER TO GENERATE THE STEAM. MOST PEOPLE FIND THAT IF THEY WANT TO JUST FRESHEN UP SOMETHING, IT WILL END UP DRENCHING WET IN THE FIRST FEW MINUTES.
Jan 18, 2010 | Malber WD1000 Front Load Washer/Dryer
Car cuts off from being wet
When you say the car shuts off from being wet, you mean the engine shuts down when it's raining, right? If not, but it still shuts down when it encounters water, this article specifically addresses your problem:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Engine_System_Engine_Quits_When_Raining.htm
There are five (5) probable causes of your engine's failure when the surrounding area gets wet, and they include the distributor and any of its components getting damaged by the water or otherwise an ignition coil being damaged.
The article above should definitely help solve your problem!
Good luck,
Brad
Jun 18, 2009 | 1994 Lincoln Continental
Admiral washer, spins too slow so clothes are still soaked
The clothes being wet and the drum spinning slow are probably due to a worn belt, tilt the machine back and the belt can be removed and replaced from below with no tools.
If the machine is constantly filling with water the level pressure switch requires changing. Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, the pressure switch i at the back LH side, you will see a small pipe attached to it from lower down the drum, replace the pressure switch pull off the terminals and the hose and replace using the same order of connections.
Apr 14, 2009 | Admiral AW22 Top Load Washer
Unit only works upside down!
there is a water level next to the ocilater make sure that the canal is clean. try some water and vinegar
Apr 07, 2009 | Venta VS 100 Humidifier
Lights dim, wipers slowdown after running through averge puddle
dont go through puddles check plug wires for dielectric grease first. then let me know if it works
Mar 20, 2009 | 1998 Mercury Grand Marquis
THE MOBILE IS TURN OFF AND ON RESPECTIVLY
DId you get the cell phone wet anytime recently?
Dec 06, 2008 | Sony Ericsson K750i Cellular Phone
Samsung D880 Cellular Phone Logo
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
