Home | Xerox | WorkCentre M15i Laser Printer | I use xerox M15i pri...
Xerox WorkCentre M15i Laser Printer
Problem for Xerox WorkCentre M15i Laser Printer
I use xerox M15i printer.i used xerox pe 16
By freesmiles95 on Feb 24, 2009
i use xerox M15i printer.i used xerox pe 16 before.i could use zoom action from pe 16 but i cant do that from m15i.is there any driver for m15i to use that zoom action??
Clarification Request
Posted by l2p3456 on Aug 02, 2009
mean enlarge?
Solution #1
posted on Oct 17, 2009
Not Rated)
gilbertgonz8
Rank: Guru  Xerox Computer Hardware  Expert
Rating: 93%, 25 votes
I believe you are refering to the Xerox XD Pro 16. And this machine is the M15i.
If this is the case, the two machines are very different, driven by their own software. They operate different.
If this is not the case I would be interested in hearing this again.
Was this helpful?
Yes
No
Solution #2
posted on Sep 15, 2009
Not Rated)
IMAZIGHEN
Rank: Wiz  Xerox Computer Hardware  Expert
Rating: 77%, 8 votes
tried install the printer from its original cd
Was this helpful?
Yes
No
Popular Solutions for Xerox WorkCentre M15i Laser
Questions and Unsolved Problems for Xerox WorkCentre M15i Laser
Do you recommend Xerox WorkCentre M15i Laser Printer?
Answer
Answer
I press print then the cannon 600 reads out no paper! load tray .Even though its already loaded.
Answer
i need a meter reading for a konica magicolor 2400W. How do I do this?
Answer
I enter CREATE PDF FROM SCANNER. Select XEROX M15WORKSERIES. ERROR MESSAGE : CANNOT BE SET TO THIS... (More)
Answer
I have problem in my printer it is not accessing the order threw the my pc
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xerox WorkCentre M15i Laser...:
Top Printer Experts
Rank: Guru Guru
Solutions: 500
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
