Question about Panasonic KX-TA308 Phone
I need the programming manual for panasonic kx-ta308/616
I don't have the manual so i cannot program the pbx
  • task982 Mar 02, 2009
    Best solution is to download the manual in PDF format.
    International phone calls will be too expensive solution
  • Anonymous Mar 23, 2014
    I need the file to upgrade the pbx panasonic kx-tes824 from ver 2 to ver 3 thank
Try this for size...
Posted on Sep 08, 2009
  • Mikrobi Apr 28, 2011
    It's too small to make out what it sais
  • 3 Answers
Does anyone knows where to get panasonic kxtem824 programming manuals?
Posted on Aug 05, 2010
Mother board problem
Posted on Jan 11, 2010
  • 4 Answers
Phone 0121 350 3030 and we can help , either send a manual or help you programme over phone
Posted on Feb 26, 2009
2 Suggested Answers
SOURCE: how to program the PBX
i want to reset my pabx machine and programm it all by kx t7730 by my self how i can pl plz
Posted on Apr 01, 2011
Change auto attendant panasonic t7731
You may download a copy of the quick reference guide at http://www.ask-tsc.com/pdf/KX-T77xx.pdf
The KX-T7731 is just the phone. The auto attendant is controlled by the PBX. To change the message, please consult the manual for the PBX. If you don't have that manual, please reply to this post and specify the model of your PBX.
Mar 24, 2014 | Panasonic KX-T7630 Corded Phone
Our company uses the PANASONIC KX-T7730 phone system, just wanting to know if customers can call directly to our extension numbers?
if your pbx has a built in disa feature, then you need to program
the DIL (sys. pgm. # 418) to DISA-OGM 1. Then you need to
record an OGM (program 9,1,1) to tell you customers that
they can dial the ext.# directly.
Oct 29, 2013 | Panasonic KX-T7730 Corded Phone
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
I am using Panasonic KX-T7730 i could not make out going calls wich strarts by " 0 " i change my phone but the problem is still there My extension number is 114 we are using pbx system
Is your extension programmed to allow dial 0 calls? The phone is just an instrument, it has no programming. Guess where the program is and who controls it? Yep, see your system administrator.
Carl
Apr 14, 2011 | Panasonic KX-T7730 Corded Phone
I need cinfigaration pbx tes824 via kx-7730
The programming of a Panasonic system is located in the Installation Manual. Our US systems differ, so the link to my public website probably won't help you. Check with your Panasonic dealer and look around for a CD. In our systems, the manuals are delevered with the system on a CD.
Carl
Sep 21, 2010 | Panasonic KX-T7730 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
Registration of ps in pbx
i have a problem in panasonic pbx TDA 620 which tells all extensions are buzy when hhave been called and the stat of the card nothing neither red nor green solve this problem for me please thanks as always for your help
Sep 16, 2008 | Panasonic (KX-TDA200)
Help
You needs to enter to a program mode inside the PBX option.
the name Its inside the PBX.
Once you on the Extension 101 enter program mode press choose program 004 select the station number and put the new employee`s name.
Jul 11, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-TA308 Phone Logo
2,121 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
