Question about HP DeskJet F380 All-In-One Printer
Color ink ceased after 10 copies
Deskjet D2568
  • Roberta Smith
    Roberta Smith May 11, 2010
    brand new printer ?
    New Friend:
Posted on Mar 14, 2013
  • TARUN DAS Mar 14, 2013
  • 46 Answers
I think u are using the introductory cartridge which comes when the printer is new and it only has one forth the ink of original cartridge
Posted on Feb 24, 2009
How do i put in the ink carrages
Lok at :
2-or this
Feb 12, 2015 | HP Deskjet 2540 Inkjet Multifunction...
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions): (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout. (HP 60 - Deskjet F2400/F4400/F4500 models) (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video:
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site:
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video):
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Close the print cartridge door.
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
Printer does not print
The following hints might help:
1. It is better to reinstall the driver (from hp site)
2. Do not on the printer until the usb cable is plug to computer
3. If it happens offen, you need to off the printer using printer switch and not from power source. You may have a habit of unplugging the usb cable without off the printer swich.. this will later lead to switch chip damage.
Apr 17, 2009 | HP DeskJet 3745 Printer
Printing problem
Have you tried changing the cartridge or refilling the black and colored ink cartridges?
Jul 25, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet 5940 reversed ink cartridges
It is best for you to take time to a Hp Center. You will damage the cart if you try to take them out. Hp service center has special tools which they use to take the cart out. If you are really good to them they will even do it free for you. It will not take more than 10 mins for the job.
Nov 21, 2007 | HP Deskjet 5940 Photo InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
65 people viewed this question
Ben Johnson
