Question about Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS)
Weak signal -2
Can I rig the internal wireless card in my Presario 2100 labtop for stronger signal? Like a home made antenna. And if so, where do I start on my notebook? Youtube does not show this.
  • 2,386 Answers
No way, except to put the notebook to the strong signal area.
Posted on Feb 24, 2009
HG8245A VS HG8245: The same Wifi Signal Strength?
Probably not...... With an External Antenna, there is nothing to stop the signal, whereas with the Internal, the Signal has to penetrate the case, before it goes to wherever...... I suggest using the External for the extra distance.... With 2 way radio the clearer the area yo have the Antenna, the greater the distance.... same here.... just using different Frequencies.
May 08, 2014 | Computers & Internet
Hi,ihooked up my router weeks ago and im still having very ,very,low signal, now i have no signal at all
The goal is to isolate the problem to either the environment, the computer hardware or the wireless router.
Location of the router versus the PC isn't critical unless you have lots of competing devices, wireless home phones, other wireless routers (apartment buildings always lots of them now) microwave ovens, etc. Walls, furniture, metal appliances, etc can also sometimes be a problem, Try moving the router closer to the PC to see if it helps.
If you have another router try it and see if the signal is stronger. If no, the problem could be in the PC. If you are using an internal wireless card (laptop) the PC might need to be elevated or an external antenna attached if one is available. Reseating the wireless card (or the internal antenna wire) inside the laptop might also help.
If you are using a usb wireless adapter try a 6 foot usb "extender" so the wireless adapter can be moved up to a higher location.
If you're tapping in to your neighbor's wifi, sorry, can't help you with that. Sorry if that offends you but you'd be surprised how many people ask for help with that but don't tell the truth about how they are connecting, and just lead the technician on a wild goose chase trying to solve non-existent problem!
Jan 06, 2011 | Computers & Internet
WEAK signal :-( How do I extend the distance or wireless reach.
Either look into getting bigger (higher gain) antennas for your router, or get bigger/stronger antennas for your PC's.
Other than repositioning the existing antennas or putting the router higher up in the air, there isn't much you can do.
May 26, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Compaq presario 2100 how to install a Wireless pci card
If there is no antenna then you'll have to buy the wire set via eBay, take apart the lcd, remove the top assembly of the laptop and then run them through the computer and put everything back. NOT FUN.
It's probably much easier and realistic to just purchase a usb wireless card.
Hope this info helps.
Let me know if you have any other questions.
Best of luck!
--RescueTechLA
Nov 28, 2009 | Computers & Internet
My wireless router signal is weak. How do i make it stronger so i dont have to be sitting next to my router to use my laptop?
connect wireless receiving antenna to laptop (if you have input for it in your wireless card), or connect transmitting antenna to router, or both
Nov 01, 2009 | D-Link DIR-615 Wireless Router
Very short range
No this is not typical if the Network card and router are just one room away. However electrical interference and walls do impede the signal.
Try moving the Router around to see if the signal improves.
You can also adjust the antenna and pointing it in the direction of the Router.
1. Position your wireless router (or wireless access point) in a central location.
2. Move the router off the floor and away from walls and metal objects. (Such as Metal file cabinets)
3. Replace your router's antenna.
Antennas supplied with your router are designed to be omni-directional, meaning they broadcast in all directions around the router. Upgrade to a hi-gain antenna that focuses the wireless signals only one direction. You can aim the signal in the direction you need most.
4. You can add wireless repeaters. (just the room next door this would be a last resort if all else fails)
5. Change your wireless channel. You may find one that will transmit a stronger signal.
6. Reduce wireless interference
If you have cordless phones or other wireless electronics in your home, your computer might not be able to "hear" your router over the noise from the other devices.. To quite the noise, avoid wireless electronics that use the 2.4 GHz frequency. Instead, look for cordless phones that use the 5.8 Ghz or 900 MHz frequencies.
7. Update your firmware or your network adapter driver
Source:
http://www.microsoft.com/athome/setup/wirelesstips.aspx
Nice diagrams on this web page too.
(Couple items left off as these did not seem to fit your current situation)
Oct 06, 2009 | Belkin Dual-Band Wireless A+G Desktop...
I hooked an antenna up and can't get a picyure!
I assume you have tried to retune the TV & angle the antenna in different positions. Very often, due to the location of your home & the strength of signal in that area, you usually find that , no matter what you try, an indoor antenna is just not strong enough to pick up in a weak reception area. The only alternative is to try & add a signal booster onto it or much better still ( and a lot less future reception problems) is to rig up an outdoor antenna.
Sep 01, 2009 | JVC AV-32D305 32" TV
Weak signal!
your antenna can be seen at the bottom of the laptop. it looks like a battery of cellphone bit it has buttons for wire connections, actually it is called internal wireless card. there are many ways in boosting the wireless signal you can easily search how to boost wireless signal from youtube and you will see exaclty how it is done.
Feb 24, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Installing a wireless card in my presario 2200
The easyest way would be to buy a USB wireless adapter.
You just plug it in install the software and thats it.
I'm useing a TPLINK USB adapter, it cost me 20 €
You can also use a internal card, Mini pci most likely. very simple to install also but you might have signal - antenna problems. But this tplink has worked very well in my home and in the city.
May 17, 2008 | HP Compaq Presario 2200 Notebook
Want to increase my wifi signal
usb not bestto use need new wirless n linksys ok on sale 99 cc this week and n pcmia card to go in labtop up to 1000 ft away 5 bars ok
Feb 06, 2008 | Televison & Video
Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS) Logo
218 people viewed this question
Top Broadcom Computers & Internet Experts
Prashant M
Prashant M
Laxman Bisht
Laxman Bisht
Computer Links
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
