Question about Sony Ericsson W200i Cellular Phone
I have a problem about autorun can u solve it?
    President:
  • 1,952 Answers
Was facing the exact same problem with my W200i. I formatted my memory card using the "Quick Format " option and then re-uploaded my songs. That solved my problem. There is no disturbance in between songs now, also the "Playback Failed" error has also not occurred again.
Posted on Feb 24, 2009
Autorun
Remove Computer Virus
Remove Computer Autorun Virus
When I copy any data from removable disk A Folder auto copy in every folder
1.You should install a update antivirus and scan all drive .[antivirus like avast / Symantec etc.]
2.Your problem must be solve.100%
May 10, 2013 | PNY 8GB HP c500w USB Drive
Tip
Windows Cannot Find "Copy.exe"
When i installed AVG Free last time it removed few virus including "copy.exe". so whenever i go to "My Computer" (win key + E) and double click on any hard drive then i find an error stating that (Windows cannot find "Copy.exe").
Solution:
Well the solution for this "copy.exe" conundrum is to get rid of a file called autorun.inf in each of the infected hard drives. here's the solution for the problem......
Make sure you or the virus scanner is run through the infected hard drives/flash drives. to make sure the virus files is gone.
Now, some forums said you could just select "Show Hidden Files" from the option and this would enable you to see "autorun.inf" file.
Also, some entries in the "autorun.inf"may be legitimate. so to check the file (even when you can't see the file) do this: Type in the infected hard drive label followed by autorun.inf for example f:\autorun.inf
This will load autorun.inf file in notepad.if the only entry is that incriminating copy.exe then this is what i did. i tried to overwrite the file with the same name autorun.inf. that din't work because autorun file was readonly. so i saved that blank file on the desktop and simply cut it and pasted it into the drive, then selecting the overwrite option. that should stop that annoying windows cannot find "copy.exe" message every time you double click into a drive. this will solve the problem!
Read more: http://comsguru.blogspot.com/2009/12/windows-cannot-find-copyexe.html#ixzz0nMpOFGpo
on May 08, 2010 | Computers & Internet
Sir em using kingston 2gb usb.bt the problem is that i have deleted autorun fron it,so it is not running in my car fm modulator
Solving this program is SIMPLE. Your BEST option is to contact Kingston directly:
http://www.kingston.co,/support/default.asp
Answer the questions on that page and follow the prompts to get help from Kingston. They will know how to help you solve the problem at no cost. They can e-mail you the proper AUTORUN.INF file; you can then COPY it to the USB drive so it will work again. KEEP A COPY OF THE AUTORUN FILE IN A SAFE PLACE, in case this problem occurs again.
Good luck; let us know how this turns out.
Apr 15, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Startup programs sometimes late
The reason for start up programs running late is because there are more programs installed in the computer and it takes lots of time to get these programs to run during startup. Some of these programs are not too useful but will always delay a computer startup. More and more people are becoming aware of how important it is to take control of the "autorun" programs on their PCs. In case you didn't know, an autorun or startup program will launch automatically when Windows starts. Quite often, it's a useful program and you can find it's icon in the system tray. However, sometimes an autorun is not that useful. You may not know it's installed because it's hidden or you've forgotten you installed it. When that happens, these not so useful programs are taking up processor cycles and eating up system memory. Your PC gets slower as more hidden programs are launched as an autorun. Fortunately, there are several ways to take control of the autorun programs. Windows has a utility built in called "msconfig", and there are also quite a few third party autorun apps such as this one: Autoruns by Sysinternals. Autoruns is offered for download as a ZIP file. To install it, extract the ZIP file to a folder somewhere on your PC. You'll see the following four files in the folder. lonerangerx7.png
Double click the "autoruns.exe" file to launch the program. Here's a peek at Autoruns in action. lonerangerx7_0.png
If you find a program you aren't familiar with, you can right click on it and choose the "Search Online" task. That will open your web browser and send you to the search results for the file or process that you have highlighted. In order to stop a program from running at startup, you can remove the little check-mark beside it. The interface may look confusing at first, but if you run into any problems, you can always consult the built in help from the top menu. I hope this explanation helps in solving your problems
Dec 15, 2010 | Computers & Internet
I Have a computer its local drive d,e,f cant open when we double click over it give massage open with to select a program but when i explore local disk it has been open plz give me proper solution to solve...
Its Virus Problem.. Install Bit Defender Total Security 2010 or Mcafee Enterprise 8.7i with latest patch. Scan the entire Drive.. Delete all Autorun.inf files on the above said drives.. this solves your problem..
May 29, 2010 | Computers & Internet
Worm.win32.autorun.blw virus appear in my system i already use kesper sky, but not solved. please advise a solution. thanx
When the executable is run on the victim's machine, the worm copies itself to the following locations:
  • %Application Data%\remove.exe (Copy of itself)
  • %Application Data%\autorun.inf
Where %Application Data% = c:\Documents and Settings\All Users\Application Data
Autorun.inf has following command
Exp: [autorun]
shellExecute=remove.exe
The worm adds a Run entry in registry so that it executes itself at every startup:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    "(Default)" = "%Application Data%\remove.exe"
Symptoms -
  • Presence of above mentioned files.
  • Presence of registry entries mentioned above.
Method of Infection Method of Infection - This worm spreads by using autorun.inf on shared drives and removable devices.
Removal - A combination of the latest DATs and the Engine will be able to detect and remove this threat. AVERT recommends users not to trust seemingly familiar or safe file icons, particularly when received via P2P clients, IRC, email or other media where users can share files.
Thanks for using fixya..
Sep 14, 2009 | Computers & Internet
I cant open disc D?
u can open drive D by typing "D:\" on the address bar or RUN
there is a hidden files u must delete them, to solve ur problem try these steps :
Go to command prompt and write this command
c:\> attrib -r -s -h autorun.inf
c:\> del autorun.inf
d:\> attrib -r -s -h autorun.inf
d:\> del autorun.inf
restart the pc
it will be solved
contact me if this problem still exist
Mar 14, 2009 | Computers & Internet
For virous w32.autorun.Gen in
1. Click on My Computer.
2. Go to tools.
3. Click on Folder options...
4. Click on view.
5. Set Restore Default.
6. Click on OK.
Ankur Panchani
u can contact to me at
ankur.panchani@yahoo.com
Jan 10, 2009 | Sony NW-E003F MP3 Player
My computer does not have a AutoPlay feature in it so I can insert and run my Cd-ROM PC games. It must have come with one but I can't find it.
Enabling AutoPlay on a data and audio CD (Windows XP)
  1. Open My Computer or Explorer
  2. Highlight the CD-ROM drive, right-click the CD-ROM drive and click properties.
  3. Click the AutoPlay tab. Within this section you will be able to specify all Windows AutoPlay features.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 26, 2008 | HP Computers & Internet
Autorun.exe
Click Start >Run >type > msconfig >click startup >select disable all > restart machine > problem has solved
Jun 21, 2008 | Microsoft Windows XP Professional With...
Sony Ericsson W200i Cellular Phone Logo
48 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
