Question about LG WM-2277HW Front Load Washer
I need to replace roller's on LG Tromm Gas front load dryer
The back panel seems to be stamped to the side panels. How do you take apart the dryer to get at the inner workings?
  • David Gustafson Mar 01, 2009
    I found a service manual on line at Manual Universe which has detailed instructions for removing the various panels. Thank you!
  • 21 Answers
There are 4 screws holding on a plate on the back. It is not the whole panel. Are you trying to get at the ball sensor?
Posted on Mar 01, 2009
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: need to replace roller's on LG Tromm Gas front
Unplug power cord. Remove phillips head screws on the bottom side of the "L" bracket on the back side of the dryer's top. Use the flat sides of your hands to sharply push back on the dryer's top, sliding it back about 2 inches and then lifting it off. Remove screw from top corner front corners and pry control locking tabs off from along top edge. (watch for sharp edges) Swing control panel up onto top of dryer. Remove the two screws at the bottom side of the door opening and the four screws along the top of the front panel. Unplug the light, door switch, and also the moisture sensor (by the bottom of the drum) then remove front panel. Remove four screws holding front drum support and lift up on it a bit to remove. Look at how the belt goes around the motor and pulley before removing, then take out drum. You will need to remove the phillips screws from behind dryer to remove the rear drum support assembly, allowing you to get to the nuts on the back rollers. First time job: maybe 2 hours. Second time: maybe a half hour, tops.
Posted on Feb 24, 2009
Belt come off! Need access
depending on the way the dryer is built you may need to take the dyer's top panel off then the front panel of the dryer to get to the internals while laying the dryer on its back to make it more easy to put the dryer back together when done if the belt however has snapped you can actually buy belts for the dryer you own er....one more thing make sure its unplugged before doing any of this but while its apart take your time to clean the dryer out with compressed air this will prolong the life of the dryer you own as well all dyers are easy to take apart and put back together as everything just snaps into place or screws back into place (PS: i worked on a LG TROMM dryer and it was easy as pie to put back together after cleaning and diagnosing it)
Feb 22, 2017 | Dryers
Disassembly of an LG DLGX2802L Dryer to replace gas oriface
The top must come off in order to work on orifice. remove the top and then remove the side nuts and it will slide forward after the top off.
Jun 19, 2009 | LG DLG5932W Gas Dryer
After replacing rollers on a LG TROMM DRYER. it won't spin
I would check to see if I put belt on right. There is a belt switch the must engaged. Also is the door switch plugged back in?
Feb 07, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Cracked drum lg tromm dle2512w dryer. is it worth replacing? dryer is about 3 yrs old
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Sep 25, 2010 | LG DLE2512W Electric Dryer
I have a front loader LG Tromm dryer that has a crack in the drum. Can this be self repaired anad if so how? Thanks
I HAVE REPLACED SEVERAL OF THEM. THE ROLLERS CAN GO BAD AND THE TUB IS SUPER THIN. IT USEUALLY CRACKES AT THE WELD IN THE BACK. THERE MAY BE A RECALL ON THAT BY NOW. THE LG COMPANY MIGHT SEND YOU A NEW TUB AND ROLLERS IF YOU COMPLAIN TO THEM ENOUGH. UNTIL THEN ALUMINUM TAPE IS A TEMPORARY REPAIR
Nov 03, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Need to replace roller's on LG Tromm Gas front load dryer. The back seems to be stamped to the side panels. How do you take apart the dryer to get at the inner workings?
Feb 24, 2009 | LG WM-2277HW Front Load Washer
LG DRYER MAKING CLUNKING NOISE
Clunking could be from bad rollers or cracked drum. Check the drum seam for a crack. If its the rollers you can do the same thing as drum replacement only order the rollers. I got my parts from Sears parts. The below is for a 2514 but should be close for yours.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Feb 10, 2009 | LG DLE2515S Gas Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
337 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
