Question about RCA Analog (RCA) to Digital (VGA) Converter for PC (displays TV image on PC) (AD01)
VGA RCA connector
I have a vga rca connector and I'm trying to connect my first desktop I had, DELL OptiPlex GX150 to a SANYO Tv "Not LCD or Plasma" Just basic Tube type. and I don't get anything but the normal blue screen. The same screen set for my Nintendos or PlayStation2. I hooked it up to my Sony PSone's little LCD and I get a picture but its black with somewhat like white rain coming down the screen. Still no display. The seller told me all I have to do is just plug it in, No Drivers needed. To see what I have go to www.google.com images, type "vga rca connector" and its the very first image of what my VGA/RCA cable looks like. Yellow RCA, Purple S-Video, Blue VGA.
The Tv has "NO" AV ports only a Cable Jack witch my AV ports are run off the VCR. The Tv is a 30" I think and the only date I could find on the back of the Tv is SANYO 1994 Color Black. I plane to get a New 40" LCD Tv later but can't afford one right now. I went to bestbuy to check some and they come with AV Ports, S-Video and even a VGA Port NOW.
But right now I want to find out how to get it to work on my current Tv.
5 Suggested Answers
SOURCE: RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Posted on Apr 03, 2008
jewellgirls
  • 12 Answers
SOURCE: TRYING TO HOOK UP OLD
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Posted on Oct 16, 2008
rcirone203
  • 70 Answers
SOURCE: RCA Converter auto shut down on TV with NO RCA Converter attached
You should check with the translator system. Sounds like it is on there end.
Posted on Jul 16, 2009
SOURCE: RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Posted on Aug 12, 2009
joez47
  • 61 Answers
SOURCE: RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Posted on Sep 13, 2009
CHANEL SCAN A RCA TV CONVERTER BOX
If the box has been installed correctly, you should be able to press SETUP (or some equivalent) on the remote to display a menu of choices including channel scan.
Jan 03, 2015 | RCA Analog (RCA) to Digital (VGA)...
I need the code for rca digital conv.box
Which code? For the Universal Remote? If so, it has a scanning function on it.
Dec 18, 2011 | RCA Analog (RCA) to Digital (VGA)...
What is MAxmedia tv for?
its a VGA to s-video/composite(rca) converter. it allow you to connect a computer to a tv with compatible inputs. Example would be to connect your laptop to a tv to show videos or pictures at a family gathering. you connect a VGA cable to the VGA output on the laptop(usually blue) connected to the MaxMedia TV II Plus, then from there you could connect a set of rca to the tv and view whatever the laptop sees on the tv screen with audio.
another example with a diagram
hope this helps
Apr 18, 2011 | Umax MaxMedia TV II Plus (MTMD-83611)
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
Jul 16, 2009 | RCA Analog (RCA) to Digital (VGA)...
Connect my gateway laptop to my phillips tv
It is very difficult to hook a laptop to a TV using the method you are trying. To get it to work go into your display settings (right click on desktop, go to properties, settings tab) and drag the slider bar all the way to the left (to the lowest possible setting, the numbers should get smaller as you slide it). Then try again. Currently the resolution is not compatible with your TV.
Jun 24, 2009 | Televison & Video
Ive just bought a TV to PC(VGA TO TV Converter), ive connected everything and i can see my laptop screen on the TV monitor but there is no sound
I dont think the unit is designed to use sound, it just converts vga to tv, you may have to use a 3.5 to rca phono audio cable to go from the laptop to an audio device, or an imput on your tv
Nov 07, 2008 | StarTech.com VGA to NTSC/PAL PC to TV...
KWorld PC to TV Converter
I had the same problem. It turned out the issue was that I had the VGA Y-cable connectors between the PC and the KWorld box reversed. They look like they should be interchangeable, but they are not. A closer look at the cable connectors shows that one is marked "PC", one is marked "Monitor", and the 3rd is marked "SCAN CNVTR". Once I got them plugged into the right places, I got the screen image on the TV.
Jan 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
RCA Analog (RCA) to Digital (VGA) Converter for PC (displays TV image on PC) (AD01) Logo
224 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
