Question about SAMTRON 55V 15" CRT Monitor
Samton 56v monitor all out put voltages are ok but not powering on the monitor
All voltages are ok but not powering on
Posted on Mar 10, 2009
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
Samtron 56v power
solution 1 please replace the horizontal output transistor in near to line output
solution 2 in case you changed the horizontal output when the problem not solved follow this.
monitor line output transformer burned replace them its kept on monitor from mother board to connect thru picture tube. very carefully to change the part because its have a storings voltage capacity in heavy.
solution 3 check the signal cable
May 01, 2013 | SAMTRON 55V 15" CRT Monitor
I have a monitor samsung and no power on it I check the fuse its ok and i found a power on power circuits what i can do
go to authorized personnel...don't try to do it by urself..
it contains more than 25000volt at EHT & power supply is most complicated circuit of monitor, so don't try it.
Aug 23, 2010 | SAMTRON 55V 15" CRT Monitor
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
In my SAMTRON 56V monitor problem
my samtron 56v problem stand by when i power off yet i power on it is off position whats problem with me.switch is many time pressing then is on position.what is parts of my monitr suplly fault.wich part is spoil
Jul 02, 2009 | SAMTRON 78DF 17" CRT Monitor
Horizontal width problem
1. change the flyback 1600v working voltage pf.(near to Horizontel transistor.)
Dec 10, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Screen menu displays locked & unlocked
possible faulty VGA Controller board.
Dec 03, 2007 | Gateway FPD2275W LCD Monitor
Samtron 56v moniter on but wosulation not coming
samtron 56v monitor wosulation problem how can i sovle this problem
Sep 28, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
88 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
