Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Intermittant problem Sears 139.53646 SRT opener. Opener light goes on and off and relay clicks when is use or when I hit it on the side of the opener. Happens with door connected and disconnected. Green light on push button goes off when main opener light goes off. Seems like overall power to the unit turns on and off.
  • Pete Feb 24, 2009
    My 13 year old Craftsman unit suddenly quit working. All it does when the control button is pushed, is a click the light comes on and then a wurr from the motor for about a second and then it quits.
    I have disengaged the door fron the chain, but the same happens.
  • 118 Answers
Look at the lights on the safety eyes also. If all of these lights go off at the same time, there is definately a power issue. It is either an issue with the electical outlet or the circuit board.
Posted on Feb 26, 2009
I have an access master door opener..it goes up about 6 inches and stops, hit switch again, goes down, hit switch again goes up about two feet, hit switch again goes down, third time switch nothing until...
Door sensors have nothing to do with door opening. Only closing. It sounds like you have a bad gear in the motor unit. Remove the cover and it will be obvious if the gear is bad.
Feb 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
Where is the "SRT" button on model 139.53876? Thanks
The model number you give is for a wireless keypad. They don't have SRT buttons. The model number for the opener is on the door side of the motor unit.
Feb 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have model 139.53671 SRT gagrage door opener
If that is the right remote for the opener you need to locate the smart/learn button which is on the rear of your opener near where all those white wires go. Hold the button down on the remote and then press and immediately release the smart/learn button. It should now be programmed.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Intermittent problem w/Sears garage door opener transmitter
If the wall control is flashing, the lock has been engauged. Hold the lock button for 3 seconds to turn off. The light should be solid after doing this.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change keypad access code for Sears garage door opener
To change the code, you need to hit the LEARN button the back of your machine. You will see a yellow light flash. Enter a 4 digit code on the keypad and press enter. The lights on the opener should flash and you should hear a click. Your keypad is programmed.
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
141 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
