Question about Acer Aspire T160 (AST160UA3400) PC Desktop
Computer will not boot operating system
It will go through the action but when it gets to the part where it searches for the operating system it seems to stop. I can hit the F8 key when it is trying to boot and get into the Bio's.
    President:
  • 1,223 Answers
Check ur hard drive is it showing u in Bios the main culprit is ur Hard Drive try re loading ur operating system by formatting ur hard drive otherwise Change ur Hard Drive it hace bcame weak , there is a hard drive checking utility like HDDLIFE try connecting it to another desktop and scna it thru this software see the strength of the hard drive ur self download the trial version from website www.binarysense.com and let me know if it helps ,
basically if u computer boots ok and goes in bios when u press key that seems like ur whole pc is working ok incl RAM the only thing that is responsible for the operating sys is Hard disk it is where all files reside so when it crashes or get weak it doesnt give up files to boot so pc is unable to boot forward
pls do vote me if u find me helping and fixya problem
Posted on Feb 24, 2009
Hard drive activity LED indicator is red flashing , hp 4515s doesnt work
Blinking usually indicates activity as whereby some form of startup action is prompting the drive to boot. Failure to boot means the operating system boot sector is not starting and needs reinstallation of the OS.
Oct 19, 2013 | AMD Computers & Internet
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
My Px 7 do not start, get stuck and the screen reads searching for OS
First of all, let's make sure that the computer is booting up from the Hard Disk Drive. To do so, follow these steps:
>Turn computer ON.
>After pressing the power button to turn the computer ON, keep tapping "F12" until Advanced Boot Configuration" comes up.
>Look for an option that has HDD. Select that option using either with the "UP" or "DOWN" arrow and hit "ENTER".
>If your computer boots up, then it means that the computer is not booting up to the Hard Drive but from somewhere else. If it still does not boot up then it means that the Operating System is corrupted and needs to be reinstalled using a Recovery Disc or a Retail version of Windows Operating System.
Dec 18, 2011 | Office Equipment & Supplies
HP Compaq notebook will not boot up. It seems to start and immediately shuts down. I am unable to turn it off without removing the battery or disconnecting the power supply. This happened before and...
information. hpweb_1-2_plus.gifhpweb_1-2_minus.gifRun a Microsoft system restore
    hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows XP Click Start , All Programs , Accessories , System Tools , System Restore . Select a windows restore point from a time when the computer operated properly, and then restart the computer. hpweb_1-2_plus.gifhpweb_1-2_minus.gif In Windows Vista or Windows 7 Click Start, type restore in the search field, and select System Restore from the list. Select a windows restore point from a time when the computer operated properly, and then restart the computer.
If the computer does not boot into Windows, you can restore the computer settings to an earlier point in time. Turn on the power and press f8 . On the Windows Advanced Boot Option screen, select Safe Mode and boot into Windows. hpweb_1-2_plus.gifhpweb_1-2_minus.gifUpdate Windows, the BIOS, and HP device drivers
Nov 11, 2010 | HP Compaq nx9600 Notebook
Multiboot computer, Second OS unavailable after reinstall of XP
The problem can be solved easily if the second operating system was a windows based operating system.If it was a windows operating ,the following steps will give you a solution
In order to regain the boot path for old operating system
follow the following steps
1.Insert the Microsoft windows xp installation cd into a cd drive and boot the computer from the cd
2.In the microsoft setup page select the option of R ie recovery console
3.Select the operating system in the recovery console by selecting the operating system NO eg 1 and type the administrator password
4.Type the following command in command prompt
bootcfg /rebuild it will search for existing operating system in the hard disk and prompt you to add select yes .
5.once you completed type exit
May 06, 2010 | Microsoft Windows XP Professional
Operation system not found, cannot understand how
Try booting to the "Safe Mode" menu; but don't select Safe Mode....
Select "start computer in last known configuration"
If it boots, try to download "Stinger" from McAfee:
http://vil.nai.com/vil/stinger/
Stinger does not have to be "installed"
If you can download using a different computer, you can run it from a flash drive.
Sep 30, 2009 | Computers & Internet
Compac disc boot failure
this could be just the boot order, restart the pc and hit F1 or F2 keys, to get into the bios go to boot order and make sure the first boot device is HDD (hard disk drive) hit F10, save and reboot.
keep me informed
regards
Nov 24, 2008 | Compaq Keyboard
Mispelled administrator password
search the internet. there are cd bootdisks you can burn that when you boot from them will let you reset the password.
Here's one:
http://home.eunet.no/~pnordahl/ntpasswd/
Aug 12, 2008 | Microsoft Windows XP Professional With...
Can't get past the post
Have you set the boot sequence in the bios to cdrom first. You are installing from a winxp cd right? Also, when it past the post and starts reading the cd it will ask you to press any key to boot from cd, if you do not press any key in a matter of seconds it will search for another boot device. Since you don't have any other operable boot device, it will not boot up. If you still have problems, please let me know
Dec 11, 2006 | ASUS A8N-SLI Deluxe Motherboard
Acer Aspire T160 (AST160UA3400) PC Desktop Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
