Question about Kenmore 15864/15862 Top Load Washer
Washer- Hot water wont stop flowing
The hot water in my washer just started today to flow even when cycle is on off. The only way to stop it is to shut off the valve- the cold water works perfectly. Can I fix this and how?
  • 514 Answers
You will have to replace the multi valve inside the washer where the lines come in, not too hard if you can use tools and find all the hold own bolts/ screws. the part can be a little pricey so you may want to take it to a repair shop. make sure that you UNPLUG first!
Posted on Feb 24, 2009
I have a WTW5600XW Carbo top washer and at times hot water continues to flow even after cycle ends. Suggestions?
if it stops when you unplug it from the wall the control board is faulty, if it keeps flowing when unplugged the hot water valve is jammed open
Feb 03, 2017 | Washing Machines
Water stops flowing while washer is filling
The hot water on my washing machine abruptly stopped flowing within the first couple of seconds. After a bit of checking I found that the fill hoses behind the washer are of the sort that automatically stop the water flow if it exceeds a certain rate. They are several years old and apparently the valve on the hot water hose has started to malfunction -- it stops the water at a lower pressure than it should.<br /><br />Temporary workaround: If you absolutely MUST wash a few loads, you might be able to get it working by reversing the hose. Disconnect it from both the washer and the valve, then turn the hose around and connect it back again. The valve should not interfere with water flowing in the other direction.<br /><br />Permanent fix: Replace the fill hose as soon as possible to help prevent flooding accidents. These hoses can't prevent flooding in all situations, but as they say... better safe than soggy. (Sorry, couldn't resist!)<br /><br />Something else just occurred to me as I was writing this. Reversing the flow through the hose for a few cycles of the machine might actually help to unclog the flow-stopping valve. Before plunking down the cash to replace the hose, try reinstalling the hose in the correct direction and test to see if the water flows normally. I will try this and post a follow-up as soon as I can.
on Jan 15, 2011 | Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Hot/cold cycle stops before filling up
Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
Aug 12, 2012 | Admiral 32 cu. ft. Washer
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
No flow
Hello hedrickcari
You said, you are getting a no flow error code. This washer was installed today.If I have an air pocket, how do you get it out so the washer senses the water flow?
First I would unplug the washer for 5 minutes and see if it resets and clears the errors!
Make sure the door is tightly closed. (Unlike top-loaders, front-loading washing machines must be closed in order for water to begin filling. Makes a lot of sense when you think about it.)
Then make sure the machine is plugged in to a live (or working) electrical outlet. It's a good idea to check the appropriate circuit breaker and reset it if needed or check the fuse if you have a fuse box.
Next, turn the control dial to the proper cycle and push the START/STOP button firmly. Then turn both faucets (hot and cold) on all the way. Take a look at the inlet hoses (which go from your pipes to your washer) and straighten them out if necessary.
Turn off the faucets and then disconnect the hoses. Clean the hose filter screens to remove any blockage that could be plugging up the water line.
Then replace the filter screens, reconnect the hoses, turn the faucets back on, open and close the door, and push the START/STOP button firmly one more time.
You should be rewarded with the sound of water beginning to fill up your Maytag® Neptune® washer. If you aren't, please contact Customer Service at 1-800-688-9900.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
46 people viewed this question
Sal De
 Brian Main
Brian Main
