Question about Toshiba Satellite A105-S171 Notebook
Operating System Not Found
I power on the computer and after the 1st start up screen, it goes to a black screen. After a few lines of text, it reads Operating System Not Found. Any ideas?
  • joebklyn88 Feb 24, 2009
    Ekse, I have the recovery disc but when I put it in the cd-rom drive, I get a pop-up screen saying HARD DRIVE NOT INSTALLED-TURN OFF COMPUTER.
  • Toshiba Master
  • 13,433 Answers
Hey,
windows is not properly installed on the computer, you will need to use the windows installation disc or recovery media that came with the computer to restore it to the original state.
If you don't own either, you can take the laptop to a professional who can reload windows for you.
Or get your hands on a windows installation cd to solve the problem.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 24, 2009
Computer failing to start
Your Operating System maybe corrupted. If you have the installer that it came with (usually a CD), you may need to use that when repairing. Your computer should extract the missing/corrupted files from the installer
Nov 25, 2017 | Microsoft Windows 7 Home Premium 64BIT...
Acer Aspire 7741Z 4433 does not see the operating system, new hard drive.
with a new hard drive , ti will not have an operating system installed
turn thr computer on and hold down the delete button until the bios screen comes up
click on the boot tab and set boot priority to first device c
put the cd in the cd drive
switch off the computer and then restart
the boot will now read the cd and reinstall the operating system
when installed go back into the bios and change back to first device --hard drive
May 09, 2017 | Acer Aspire Computers & Internet
Problems with my emachines monitor. I have an Emachines monitor as my second monitor E17T4 monitor. When the machine is on sometimes it is fine othertimes the screen goes black but the power light stays...
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
Sep 30, 2011 | eMachines E17T4W 17" Monitor
My Imac crashes. 10.6.4, 2 GB ram, 2 GHz core duo. I've started with a clean install and disabled (one by one) all start up apps. Out of the clear blue, the screen will go black & I have to turn it...
When you say "screen goes black," does the computer power down, or is it still operating? Does the sleep light come on? Does it respond to the keyboard and mouse? (Example: press the power button momentarily, wait a few seconds for the "Do you really want to shut down" message to appear, even though you can't see it, then hit the return key to answer "OK," and see if it shuts down.) Does the screen go black or come out of black if you tap the computer?
While your computer is working, go to System Preferences / Desktop & Screen Saver, the Screen Saver tab, click Hot Corners, and set a corner of your screen to Put Display to Sleep. Then next time your screen goes black, mouse your way into that corner, pause a few seconds, then mouse back out and see if your screen returns.
Jul 10, 2010 | Apple iMac 17" Desktop
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
I on my my acer 4520G. At 1st it start and manage to get to windows but it hangs after that the window vista bar load from start to end. I can't get it boot afterwards. When I on it the screen only goes...
try with going to safe mode
to go to safe mode tap function key 8 continuously to see windows advanced option -> choose safe mode
if it loads to windows click on start -> all programms -> accessories -> system tools -> system restore
and restore back to earlier when the computer was working fine.
if it dont go to windows... you need to reinstall the operating system..
Dec 17, 2009 | Acer Aspire 4520-5582 Notebook
T 43 says "operating system not found"
Sounds like you have a bad hard drive. Boot up with a Windows CD and select repair at the setup menu. It should dump you to a command line. Type "chkdsk /f" without the quotes and it will check the hard drive for errors. When it's done, reboot normally and it should get you into windows. If it doesn't, replace the hard drive and install windows on the new HDD.
Oct 26, 2009 | IBM ThinkPad T43 Notebook
Eee 900A goes through fast start then blacks out
Must be common problem. Linux is the operating system
yes you just lost linux, it needs re-doing but with an external CD ROM drive unless it has a partition
for recovery in which either F10 key will do it or another key check the manual for RECOVERY of operating system its not a big problme but it takes few hours to solve
Mar 13, 2009 | ASUS Eee 4G Notebook
My computer wont start up
First try pressing F2 at start up to see if you can get to setup. Also pressing F12 may get you a boot menu. If cd is already set as first boot you may get a chance to boot from a Windows cd. The idea here is to get to a minimal Windows configuration like setup or safe mode (F8) to see if this is a hardware or operating system fault. Two common issues with eMachines are power supply problems where repetitive reboots can actually fry the motherboard or if the PC has a few years use the CMOS battery. Steve Medley
Oct 30, 2008 | E-Machines eMachines Desktop PC
Operating system not found
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Mar 15, 2008 | Gateway M305CRV Notebook
Computers & Internet Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
