Question about Dell QuietKey (310-1235) Keyboard
Keys on right hand side of keyboard do not work (Dell Quiet Key)
After an upgrade to my computer, the right hand keys (primarily the number keys) no longer works. The rest of the keyboard works fine.
Thank-you.
Michael
  • 46 Answers
Go to control panel & check for keyboard layout settings also connect another keyboard & check if it is a hardware problem
Posted on Feb 24, 2009
I can't turn the fn key off
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it.
Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
Feb 06, 2013 | Dell Inspiron 1501 Notebook
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
My number pad on right hand side is not working
Hello There
push the Numlock Key on the right hand side of the Keyboard.
that button turns on and off the keys on the number pad .
Thank you don't forget to rate
Jan 25, 2011 | Computers & Internet
Number keys on right side do not work on Dell Model SK8110
mcdevito75 here, the numbers on the rite side of your keyboard should work once you press the Number lock key at the top of the numbers keys.
Jul 21, 2010 | Dell 0Y3740 Keyboard
Keypad on right side doesn't work
Try pressing your numlock (top left of the keypad) and try the numbers again. Try your keyboard in another computer -- if they still dont work, you have a hardware failure ... time for another keyboard. If it works on another computer, then I would recommend right-clicking on "My Computer" and selecting "Manage". Go into the hardware manager, and delete your keyboard, and reboot. The Windows will find your keyboard and reinstall the drivers, hopefully resetting whatever configuration was previously blocking your keypad keys.
Apr 10, 2010 | Apple M9034LL/A Keyboard
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide
http://ftp1.us.dell.com/diags/R65848.htm#Key not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
My Dell Vostro 1000 laptop keyboard (right side) keys are not typing what I type. It is like they are out of sync. Can you help? (I am currently using a different computer to type this.
Num Lk will cause the keys on the right-hand side of your keyboard to display the alternate characters printed in blue. Just press the Num Lk key--it's the fifth key from the top right corner of your keyboard--to deselect, and your problem will vanish.
Sep 14, 2009 | Dell Vostro 1000 Notebook
Letters are typing as numbers
one of the F keys turns certain keys on the right side to number keys, so it can act like a full size keyboard with the 10 key panel on the right.. Look carefully at the F keys to determine which one it is. Or consult the manual.
Aug 31, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Key pad doe not work
This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
Any more problems, let me know!
May 26, 2009 | Dell Inspiron XPS Gaming Mouse Pad KU170
Right hand side of key board displays numbers
Your bios probably is set to use the embedded keypad when the numlock is on. you can set it to numbers only when you press the FN key
Feb 18, 2009 | Dell Latitude C640 Notebook
Computers & Internet Logo
621 people viewed this question
Alun Cox
