Question about ASUS M2N-MX Motherboard
THE DISPLAY IS ALWAYS STECK
THE DISPLAY OF MY COMPUTER BE ALWAYS STECK.WHAT IS THA REASON?
  • Anonymous Feb 26, 2009
    WHEN I CAN START THE MICRO SOFT POWER POINT & BLINK THE BLUE LINES IN POWER POINT
  • 203 Answers
ASUS is the problem!
ASUS motherboards ****.
many of them have video problems and most boards only last 18months before error.
the ASUS tech support is useless and will not help you at all.
Posted on Feb 25, 2009
NO VGA DRIVER PLEASE GIVE THA DISPLAY DRIVER OF M2V MX SE PLUS ASUS MOTHER BOARD
Go to the site below and enter the required details and you will get the drivers needed.
http://support.asus.com/download/download.aspx
Jun 16, 2010 | ASUS M2V-MX SE - Motherboard - micro ATX -...
Vga
Video Graphics Array (VGA) refers specifically to the display hardware first introduced with the IBM PS/2 line of computers in 1987,[1] but through its widespread adoption has also come to mean either an analog computer display standard, the 15-pin D-subminiature VGA connector or the 640×480 resolution itself. While this resolution was superseded in the personal computer market in the 1990's, it is becoming a popular resolution on mobile devices.[2]
VGA was the last graphical standard introduced by IBM that the majority of PC clone manufacturers conformed to, making it today (as of 2010[update]) the lowest common denominator that all PC graphics hardware supports, before a device-specific driver is loaded into the computer.[citation needed] For example, the MS-Windows splash screen appears while the machine is still operating in VGA mode, which is the reason that this screen always appears in reduced resolution and color depth.
VGA was officially superseded by IBM's XGA standard, but in reality it was superseded by numerous slightly different extensions to VGA made by clone manufacturers that came to be known collectively as "Super VGA".
Apr 14, 2010 | Foxconn P9657AA-8KS2H Motherboard
Can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
MY COMPUTER DOESNT SHOWS ANY DISPLAY .I HAVE INTEL 845GVSR.I WANT TO KNOW HOW TO CHEK THA ITS RESISTORS ARE BUBBLED?IF THEY ARE. THEN HOW TO REPLACE THEM?
Its best to first check if the PC is passing its POST, if it beeps once them thats good, if not the MoBo is faulty, and it is probably easier to get a replacement, if it does pass POST then check your monitor and cables.
Aug 11, 2009 | Intel D845GVSR Motherboard
NO DISPLAY
if your computer still fine and boot normal only display is problem?
try use another monitor might be your monitor is the the problem
or
if you have extra video card try use it if work your video card need to replace or if you don't have video card buy new one
NOTE!
Remeber while opening your computer and touching always touch to a metal to discharge the static electricity in your hand ^_^
or Bring it to PC Repair Shop for more experice to do it for you
Jun 27, 2009 | Computers & Internet
No display
hi im josh in cebu phils. friend one of the reason of the computer that will not display is the video devices. if you used video card.it is not compatible like if you use lower memory vdeo it will occure.try to use higher memory video 256 or above. or if the video is built in on the board try to go to bios setup then change.choose higher bit in the displasy settings. hope i helped you. good luck
Feb 17, 2009 | ASUS S478 VIA P4V533-MX Motherboard
Always display bad cmos setup
have you checked the jumper next to the cmos battery? check if its good not broken and also try and upgrade your firmware. visit your motherboard's manafacture for the firmware upgrade.
Nov 13, 2008 | Asrock P4I45GV R5 Motherboard
Mother board dead
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Feb 10, 2008 | Intel Motherboard
Problem with GA-8IK1100, AGP vga card can not display properly
Hi, is this a new card? I installed a simalar one in my computer [ a used card] only to find I had intermittent display. I found out later the card had been overclocked. A new card cured the problem. If this is a new card then return it for a warranty claim. Regards mistyman
Sep 03, 2007 | Gigabyte GA-8IK1100 Motherboard
ASUS M2N-MX Motherboard Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
