Question about Systemax Arrival (036063) PC Desktop
On board lan
When i reformat the pc, the onboard lan does'nt work even i installed the driver [from the cd]. can have a solution for this...,
thanks,
    Novelist:
  • 121 Answers
HI,
My name is ArmyMason, Sounds like you aer having an issue with your On Board NIC. Let me ask you have you checked the BIOS to see if its enabled? If it is I would have to say you have a bad NIC and should consider going to the local Computer store and purchase a new NIC, they are cheap and can even be found at WalMart. This could have been a result from a electrical storm and could have caused damage to the NIC. Either way the cheapest solution is to buy a new NIC.
Thanks,
ArmyMason
Posted on Feb 24, 2009
  • Systemax Master
  • 13,433 Answers
Hey,
you must have the incorrect driver installed, could you send me the brand and model of your computer.
also look into msinfo32 and provide me with the device PNP ID
start -> run -> typein: msinfo32 -> open components -> open Problem devices.
Send me the details, device name, pnp id and error if there is one.
Thanks,
Ekse
Onboard lan not working even after update of driver gives windows error
Hi Good day!! What message of windows error? Check your network adapter in the device manager, if it is install if not pls try the following.
1. On the desktop right click "My computer and then properties"
2. go to Hardware tab and then click device manager check the network adapter.
3. Disable it and then re enable it. hope your on board lan will work now if still not re-install your lan driver through your motherboard cd..
pls reply o assist you more..
REGARDS:
JR
Oct 07, 2010 | Biostar TA785G3HD AM3 AMD 785G HDMI Micro...
I have a IBM thinkcenter 8123 model. I can't install lan due to lac of suitable driver! pls help me!
Go into the bios on your computer and shut down the onboard LAN, find a 3com or realtek LAN card and install it, windows has the drivers build in for most 3com cards, then you go to IBM site, download the drivers you need for the onboard LAN connection, remove the 3com card let the computer boot up, and when it asks for the driver point it to where you downloaded the drivers for the onboard LAN.
Jun 18, 2010 | IBM ThinkCentre M50 8187 Desktop PC -...
Just reformatted my dell dimension e510, prob connecting to net
Hi there.
Use the Dell tools system software CD to install the LAN (network) drivers, just pop the CD into the drive and install the CD, once it is installed a new window will pop up giving you an option to install drivers and/or utilities, just look for the LAN or network drivers and restart the PC when prompted the LAN drivers will be installed and you will be able to connect to the internet.
Post back if you have anymore problems.
Good luck and thanks for using FixYa!!
May 09, 2009 | Dell Dimension™ E510 PC Desktop
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Asus P5k ethernet slot on motherboard just stopp ed working
Try tis...
1) Re-installing windows will not fix the problem. Try re-installing the
Ethernet driver (LAN). This driver should be on ASUS install cd.
2) Sometimes ethernet will just stop working. Then you should just
purchase a new ethernet card. They are rather cheap. Check out
Newegg website. You may have to disable onboard Lan in Bios.
Apr 25, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Can'nt Play Audio or Video files
http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1010&SubCatID=104 hello, i get all my via drivers from the via arena.(for all that is made by via) i looked up your motherboard, and came up with this, via vt8233 is your chipset- audio-lan-video-chipset driver for that board.you should do all the drivers. first the 4 in one via driver is for the chipset, then the audio-video and any others that are onboard.even if they work-these drivers are newer than the one xp has built in the install cd. so, good luck! if you need further assistance-reply. you wil be ok.please rate this solution. thank you
Apr 17, 2009 | Computers & Internet
ABIT is7-vs no ethernet
Have a closer look ... that appears to be in IS7-V2 board
http://www.abit.com.tw/page/uk/motherboard/motherboard_detail.php?pMODEL_NAME=IS7-V2&fMTYPE=Socket 478&pPRODINFO=Driver
If the link doesn't work right you may have to copy and paste the entire link into your browswer
Download the Realtek Lan driver you should be good to go
Robert
Please take a moment to rate this solution thank
Feb 03, 2009 | ASUS P4B533-VM Motherboard
Installing new Window xp and other devices didnt works
take the side of the computer off and look for the model number on your motherboard. you need to know if your using a network card or if its onboard Lan. if everything you need is onboard all you need to do is search your motherboard number on the internet and download the drivers. you need can select what you need, sound, lan etc. your goning to have to use a friends pc so you can download these files. when your Lan is installed go to the microsoft webpage and get the latest updates, that will solve the usb in your device manager
Sep 08, 2008 | Computers & Internet
On board ethernet driver conflict with windows XP
go to the bios settings & there you can disable the onboard LAN ....
so by this you will be able to boot from your hard drive ....
you can go to the bios settings by pressing F2 (or delete key in some PC s ) at the time of the booting (before the OS loads)...
there in bios settings just search for the LAN device & disable it ...
that s all your problem will be solved ....
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Jul 05, 2008 | ASUS P4C800-E Deluxe Motherboard
Systemax Arrival (036063) PC Desktop Logo
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
