Question about Kenmore 22642 Top Load Washer
Kenmore top load washer 110-24642300 is leaking when it fills
When the washer fills with water at the beginning of the cycle and at the start of the rinse cycle, water is leaking out the front. What is causing this leak? Can I fix it myself?
  • 530 Answers
Tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Posted on Mar 26, 2009
  • res9556 Jun 27, 2011
    thank you will look in the morning
I have a kenmore series 80 washering machine. The washer begins the wash cycle mormal. About half-way through the wish cycle the washer begins to fill with water again. It will fill with water until to...
the water level control has gone bad,its located in the top of the washer control panel,four philips head screws gets you in there,make sure you unplug the machine,it has a rubber hose,and four clip on wires,one 1/4 inch screw holds it in place,its job is,it works off of air pressure from the rubber hose that comes from the washer drum,if it don"t read the back pressure from the drum being filled it will over flow.good luck
Nov 19, 2012 | Kenmore 24032\24036 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    No water during any cycle.
    if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
    Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
    I have a top-load washer that began leaking at the front of the unit. The water is dripping from the front-center of the machine. It begins leaking immediately upon filling and will continue to leak for...
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number and you'll see a list of major sub-components with diagrams and parts.
    Check the area for the motor and pump.
    If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
    Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
    Sep 23, 2009 | Kenmore Washing Machines
    Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
    The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    May 31, 2009 | Kenmore Washing Machines
    Kenmore elite, water leak
    Check the mix valve area where the water enters the machine, during the fill.
    Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
    Washer keeps filling with water...
    you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
    Jan 11, 2009 | Kenmore 22422 Top Load Washer
    Clicking Sound / Kenmore Elite Catalyst
    sounds like ur coupler is bad easy fix 4 dollar part
    Dec 26, 2008 | Kenmore 22422 Top Load Washer
    Kenore 80 top loading washer leaks
    If is leaking at the front of your washer its gonna be the pump
    May 04, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 22642 Top Load Washer Logo
    428 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
