Question about Sony Ericsson W200i Cellular Phone
Hi, please help me. Iam using w200i from 1 year. But from past 2 days my battery is not charging, if i plug the charger it displays as the battery is full, after unplugging it displays battery low. Is it a battery problem?
It is a charger ic problem. refer a service station to change the ic
Posted on Feb 24, 2009
I have a Dyson vacuum cleaner cordless and is not charging the red light is blinking but there's no green light we have had it for about a year and a use it every day usually twice a day
An issue with the battery may lead to the charger not detecting, nor attempting to charge the battery. I've solved this in the past by leaving things on charge for an extended period of time (sometimes days at a time, but with frequent checks that it's not getting too hot), but your mileage may vary.
Worst case scenario, you may need a new battery or a new charger. You can buy cheap replacement chargers from China for under 10 dollars, but a battery may set you back more. I suggest buying a genuine Dyson battery if you can; a charger isn't as important to remain genuine.
Definitely look into whether you're still covered by warranty, as I know Dyson offer some pretty hefty after sales support these days (some 5+ years). If you are, give them a call and see if they can help.
Jun 16, 2017 | Dyson Vacuums
How long do i charge ever start 16b battery after filling with acid
Hi Anonymous, the "ABSOLUTE" best way is let the battery acid soak into the plates for 1 hour then connect a 1 or 2 amp trickle charger and let it charge for 24 hours for maximum battery life. Read my lips "DO NOT" use a higher rate charger for less hours it will shorten your overall battery life, trust me I was a Harley technician for over 40 years. For more information about your issue please click on the links below. Good luck and have nice a day. BU 403 Charging Lead Acid
Fill and Charge Motorcycle Battery
How to Charge Motorcycle Battery
Battery Basics Layman Guide to Batteries
May 15, 2016 | Motorcycles
Not charging flat batteries
hi, most mobility scooter charges will not attempt to charge below 10 volts,
the trick is to use a car battery charger to bring the voltage past 10 volts then you use the mobility scooter charger to fully charge.
However please be aware of a couple of points:
1. Car chargers will damage mobility scooter batteries.
2. Once a Gel or AGM battery voltage has dropped below 10 volts they may never fully hold the charge again if they do recover and that's a big if.
Regards
Robin
GeWiz.
Feb 18, 2013 | Health & Beauty
Hi I have the vivitar vivicam 8025 dont have my manual want to know how to charge my battery
First off, you can download a PDF version of the manual from the manufacturer at: http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
If you don't have a PDF viewer, you can download one from: http://www.foxitsoftware.com/pdf/reader/ (just click download under the free version)
For your convenience I've pasted the relevant information about charging the batteries from the above manual:
Please charge the battery as below 2 methods: A. Charge with USB cable Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED willbe off when charge full.
B. Charge with supplied charger Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
Please leave feedback if this was helpful. Thanks.
Apr 11, 2011 | Vivitar Cameras
I HAVE A OLDER LG SILVER IN COLOR SORTA SHAPED LIKE A COMPUER MOUSE, IT WON'T CHARGE..HELP ME PLEASE
Older LG phones use a universal charger that looks like a silver medal tube. They are very susceptible to breakage by bumping. This is probably what happened to yours. Unfortunately, the only fix is to have it repaired or replaced in store.
If this was helpful, please rank me a 4.
Mar 09, 2011 | LG Cell Phones
I bought my phone last week tat time the battery was working fine .The battery gives back up for like 3 days .But past 2 days i need to charge my battery every night and if i dont charge the phone gets...
There are two things you have tto check. 1. Your charger is perfect-check and replace it. And secondly, don't keep continuing in charging after you get indication of charging completed, remove charger.
Jan 03, 2011 | Cell Phones
What is the code for the 2003 HD XLH Sportster 883 battery / can it be charged bya a regular car charger battery ? / i have an original HD battery Any advice will help - thanks
If this is the original H-D battery in your bike, you've gotten good service out of the battery. Time for a new one. The general rule of thumb on motorcycle battery life is two years although I have seen them last as long as five when kept on a charger designed for this.
The reason for the short life is heat, vibration and overcharging.
Due to it's small size, it is not advisable to charge a motorcyle battery using a standard car charger. If they are charged too quickly, they will overheat. With the standard car charger, even with the charger set on the 2 amp position, the initial charging rate can still exceed 20 amps. You need a charger that is limited to 1.5 amp output. The new "smart chargers" are the way to go these days. The most popular of these smart chargers is the "Battery Tender" but they are also made by Yuasa, and others. They are specifically designed to maintain the battery even after it reaches full charge. A standard car battery charger will overcharge and boil the battery dry once it fully charged. Using the "battery tender", I have gotten five years of service out of batteries in the past.
Mar 26, 2010 | 2003 Harley Davidson XLH Sportster 883...
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
Sony Ericsson W200i Cellular Phone Logo
98 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
