Question about LG DLE5977 Electric Dryer
My LG DLE5977W electrical dryer won't heat
I unplugged my dryer and when I plugged it back in it won't heat. Everything else works fine on the dryer, just isn't hot anymore. Any thoughts?
  • 1 more comment
  • Anonymous Mar 01, 2009
    Same dryer, just started partially heating..takes much longer.
  • Margaret Sonnen
    Margaret Sonnen Mar 02, 2009
    Thanks! Ridiculously, I ended up just unplugging it and plugging it back in and it works now, but we'll see if it keeps on trucking. I appreciate the help, though!
  • Anonymous Mar 19, 2014
    cooling light won't go off
  • 686 Answers
Bad thermostats or heat element broken
Posted on Mar 01, 2009
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
I have a 2001 Alero, rear defrost isn't working at all, frost inside my car, won't defrost and heat isn't working! :( HELP any idea's... I thought it was the heater core but there isn't any leakage un
You definatly have water inside the car. Pull the carpet back in the front and rear checking for water leaks. The only way frost can develope inside a vehicle is the presents of moisture.
The other possibility is your HVAC drain is plugged and water has built up inside the heater motor area. Have the drain checked and cleaned.
Nov 21, 2011 | 2001 Oldsmobile Alero
My hot point dryer won't start. the turn knob isn't clicking anymore and won't wind up.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Aug 09, 2011 | Hotpoint Dryers
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
Nov 08, 2009 | Bosch Nexxt 500 Dryer
My dryer is not blowing hot air anymore
most likely the thermal fuse 279769 or the heating element 279838 if this is a newer
Jun 23, 2009 | Whirlpool Dryers
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
LG DLE5977 Electric Dryer Logo
1,341 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
