Question about Acer ASPIRE 3680-2022 Notebook
Dvd/cd-rw combo does not record
I'm trying to burn or download video snippets on a dvd+rw disc but it keeps ejecting the dvd and has a comment that says to "download a writable disc. Is my aspire 3680-2022 capable of recording or is just a player. Thanks. Bill
    Novelist:
  • 148 Answers
You may have what is called a combo drive...it can play and burn cds but can only play dvds, not burn them. Look at the face plate on the drive and see what is written on it. If it has the following:
Recordable Drive = CD Burner
DVD = DVD Player
RW & DVD = DVD Burner
If recordable drive and DVD is on the drive but no RW, chances are its a combo drive. Keep us posted.
Posted on Feb 24, 2009
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
I have benq combo cb523b my problem is combo not writ dvd
Hi Dear,
First Install the burning software and then try to write the DVD, may you have try to burn without burning software.
Click hear and get the Burning software, see the instruction of mention below.
Data Compilations
  • Burn, backup or copy your files to CD, DVD or Blu-ray Discs.
    Supports recording from command-line and BAT scripts for automating routine actions.
    Supports CD-R/RW, DVD-R/RW, DVD+R/RW, BD-R/RE and DVD-RAM media, including high-capacity double-layer media.
    Supports UDF (Universal Disc Format 1.02-2.60), Bridge and ISO9660 (Level 1-3, Romeo), including Joliet Unicode extensions.
  • Create Bootable CD or DVD. Use it as a very big floppy boot disc for recovery purposes.
    El Torito creation support with advanced options: emulation type, sectors, platform, load segment and boot message.
  • Append or update Multisession discs.
Multimedia Compilations
  • Create Audio CDs. Play a CD on your traditional CD player or car stereo.
    Supports MP3, WAV, WMA, OGG, M4A, AAC and FLAC audio formats and M3U playlists.
    Supports title and track CD-Text, including Unicode.
  • Create DVD-Video discs and MP3 CDs/DVDs.
Disc images
  • Make and burn standard or boot disc images.
    Supports ISO and CUE/BIN image files.
  • Copy disc to ISO image. This feature can be used for disc backup, as well as for disc copying.
Utilities
  • Erase re-writable CD, DVD or Blu-ray discs.
Thanks
Mar 31, 2012 | Computers & Internet
I own a Toshiba SD-3980SU2 DVD Video Player. I keep getting an Incorrect Disc comment, and bad comment. I an using DVD-RW discs. I have tried disconnecting and reconnecting the player.
You are probably using incorrect disc formats in this DVD player; try DVD+RW if you must use re-writables, or DVD-R (finalised in a recorder or burned on a PC). I doubt this model supports DVD-RW, so the problem wouldn't be with the player; it would be the formats of the discs you use.
Don't use DVD-RW discs in this player if it does not support that format.
Apr 22, 2011 | Toshiba SD-3980 DVD Player
Which disc can be used to recrord on ?
According to the user manual, the following DVD media you can record with this unit are:
RECORDING: TYPES OF DISCS YOU CAN USE FOR RECORDING
DVD+R 2.4x, 4x, or 8x ONLY; DVD+RW 2.4x and 4x ONLY.
NOTES:
It is NOT possible to record on CD-R or CD-RW discs.
IMPORTANT: It is NOT possible to record content that is copy-protected. This is usually true for most pre-recorded DVD discs and most pre-recorded VHS tapes.
PLAYBACK: TYPES OF DISCS YOU CAN PLAY
DVD discs - DVD movie discs (DVD-ROM); DVD+R; DVD+RW; DVD-RW (must be recorded using video mode or VM); DVD-R (must be recorded using video mode or VM and must be finalized).
CDs (Audio CDs, CD-R, CD-RW) - Audio CDs contain musical or sound content only. mp3 discs are CDs (CD-R or CD-RW)
that contain mp3 files. This product also plays CDs that contain JPEG files and Multisession CDs.
Video CD (VCD) and Super Video CD (S-VCD) discs - Like DVD video discs, VCDs contain picture and sound content. The difference is the amount of information that can be stored on the disc.
VCDs typically have lower picture and sound quality than DVD discs.
Super Video CDs (S-VCDs) can be used to record up to 70 minutes of digital sound and video, with MPEG-2 standard video and MPEG-1 standard audio-but you must use DVD+R or DVD+RW discs to record on your DVD/VCR not S-VCDs.
Additionally, S-VCD disc compatibility is dependent on which MPEG coding software, disc design software, and disc writer software are used; and the discs themselves.
(The above information is extracted from the user manual for this particular model and is a guide only)
I find it very strange that the user manual does not provide any information about DVD-R recording since this is a DVD recorder. I guess you could try those types of discs in it, otherwise it will playback finalised DVD-R discs recorded/burned in another machine.
I assume you have the original manual for this unit. If not, you may be able to download it free from various sites. (retrevo may have it but they may ask you for email address prior to downloading)
I hope the above information helps a tiny bit with regard to DVD formats for this unit.
Mar 12, 2011 | RCA DRC8295N DVD Recorder/VCR
Will not burn a cd anymore, trying to burn a cd of pictures, keeps saying insert a recordable disc, I AM, they are all new ones I put in!
Try the "new" disks in another computer.
Or, try "new" disks made by a different manufacturer.
I suspect that your CD-drive has "died".
So, for less than $50, you can buy a brand-new CD/DVD device for a desktop computer.
Jan 02, 2010 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
TEAC DW 552g DVD/CD rom combo drive, CD works, DVDs dont
I have your solution, but you are NOT gonna like it, so I hope you will rate it FAIRLY, even though its relatively BAD NEWS.
TAKE A LOOK AT THIS:
Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner The Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner deliver unbeatable CD speeds of 52X write to CD-R, 32X re-write to CD-RW media and 52X read as well as 16X DVD playback speeds and the drive features an advanced buffer underrun prevention technology. This disc-saving feature suspends the recording process until the buffer is refilled. No more bad discs even when you’re multitasking. It also supports EasyWrite (Mount Rainier), a new disc formatting feature that makes it easier and saves time preparing CD-RW discs for recording. Teac W552G (cdw552g/kit/b) CD-RW Burner Newbie The Teac W552G (cdw552g/kit/b) CD-RW Burner operates with: Microsoft Windows XP, Microsoft Windows...
YOUR DRIVE DOES NOT BURN DVDs, only CDS!!!
Apr 23, 2009 | Dell Latitude D520 - Celeron Intel Celeron...
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
LG CD/DVD combo does not recognize virgin DVD´s
DVD combo do not burn DVD's they can only read DVD read CD and burn CD to burn on a dvd you need a dvd writer. A DVD combo is a combination of just a DVD ROM and a CD-RW.
with some models (even of LG) you only get one drive DVD/CD-RW but in dome version it shows as two different drives DVD and CD-RW. consider this as partioning of a drive if its to be analogued to HDD (though its not partioning its just diffrent PROMS)
Hope you understand that there is nothing wrong with your combo its just that you are expecting it to be a DVD-RAM which it is not.
Mar 25, 2008 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Open Questions:
Acer ASPIRE 3680-2022 Notebook Logo
246 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
