Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Big bass My big bass speaker dont thump no more, power is goin to everything, is there a button on the face I might have hit with my big fingers? Could it be the speaker itself? Or is it the tunner? The amp says all is good but nothing is coming out my big speaker. I don't over play it where it would blow so what is it ?! pls thank you!
    Scholar:
  • 61 Answers
Hi there
you hit a button marked SW press this button again and subs will turn on its the first button located next to number 6 on your unit
hope i was able to solve your problem
Posted on Mar 05, 2009
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Jan 28, 2014 | Mackie TH-15A Active DJ Powered THUMP...
Amp has power, but barely any power is getting to the subwoofers themselves. No thump, just minor vibrating.
Turn the GAIN up on the side of amp.
Make sure the bass is up on the deck
make sure the rca cables are coming from the "rear" terminals of the deck.
Make sure they goin to the "IN" of the amp
make sure amp is in LOW PASS not high pass or mid
Jan 12, 2011 | Car Audio & Video
How to mount a bandpass sub
usually you will get the best sound with the box mounted approximately 3" away from rear of trunk with speaker facing toward the rear of trunk if it is a single speaker enclosure you want to do the same just offset it to one side of the trunk corners always amplify sound however just so you know 10's are not really made for low bass they usually have more of a hard hitting pound instead of a low rumble usually 12's will give you the low bass better and it also depends on what kind of box a vented box would be best for low bass sealed box gives you tighter bass but you need more power ported is good for low bass but gets sloppy when loud and a bandpass is used for loud hard hitting bass
Feb 27, 2010 | Car Audio & Video
My infinity reference 7540a amp cuts in and out with heavy bass when the ''loud'' feature is on. I redid my ground, remote wire, shortened my power cable, and double checked all speaker connections. I dont...
sounds like ur gains are set to high and is going into protect mode
also what ive seen happen before is the speakers (if mounted in metal shelf or door and arnt bolted down correctly can flex under bass notes and flex the speaker that much the termanls short onto the metal and amp hits protect mode
(rare but worth a look if you think u have elimanted most other things Had a dude come to me when i was working in sydney with this problem )
also could be things like clipping protection , overheat protection ,amp drawing to much current from the alternator
do your lights dim when you hit the bass notes ?
get back to me and im sure we could solve this problem
Jan 22, 2010 | Infinity Reference 7541a Car Audio...
Makes head lights dim wen bass hits.
You need to install someting called a power cap. the amp needs so much power to produce the big bass thump that the alternator cant keep up. Use a powercap and its like a power reserve.
Jan 13, 2010 | Power Acoustik Car Audio & Video
I just bought 2 12 incch explodes the xs-l126p5 modle and i have a 1000 watt explode amp xm-1652z modl. in a bandpass box. it dont sound the way i expected to. if you can help...
Did you have it hooked up by a professional or did you (or someone you know) do it. If a shop/pro didnt do it make 100% sure everything is hooked up right. Increase the size of your power wire from your battery to the amp. Check your gain settings on the amp. If the vehicle you have this in has a trunk (not a hatch back), position your speakers against the back seat facing you as your putting them in the trunk. If none of this works, buy bigger speakers and more power!
Jun 15, 2009 | Car Audio & Video
Speakers are thumping and cracking when powered up...why?
you are better off setting your deck speakers amp to a high pass filter setting on the amp. Adjust gains to increase desired bass and clarity. Turn off loud button if you have one, that will distort your deck speakers.
Feb 13, 2009 | Power Acoustik PTID-8960 Car Video Player
Sunfire True Sub Constant Hum & Thump on Initial Signal
IF THE SUB HAS AUTO SIGNAL SWITCH THIS OFF BUT TO BE HONEST IT SOUNDS LIKE YOU HAVE A SPLIT VOICE COIL.
Jun 20, 2008 | Sunfire True Sub Signature Subwoofer
The bass box
Hi Jamesroy,
Remove the Audio inputs from the bass box to see if the thump is coming from the Audio input. Of course do this with everything turned on. What we are trying to figure out is where the thump is originating from. If the bass box does not thump when the audio inputs are disconnected, the thump is coming from somehwere between the bass box and the circuits inside the head unit.
If you still have the thump after the Audio input wires are disconnected, then your bass box's amplifier has noise problem. You might try getting a noise filter from best buy to put on the power supply feeding the bass box.
Nov 30, 2007 | Pioneer DEH-P7400 CD Player
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
61 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
