Question about Sanyo DS31590 31" TV
Sanyo 31'' Standard Def CRT TV
I fell asleep last night watching TV. When I woke up this morning, the picture was black except for a thin line across the center of the screen. This TV is over 5 years old, but I have never had any kind of problem with it whatsoever. Any idea what has happened and about what it would cost to repair?
  • Paul Atchison Feb 24, 2009
    Thanks for responding. Yes, I have the model number correct. I'm fairly competent with a solder gun and I'm not afraid to fix this one on my own. Does an IC really just work one minute and **** out the next?
  • righter1 Feb 26, 2009
    I have the same problem with my TV. It did this last night, and would sometimes flip back to a normal picture, but now it seems stuck on the thin line. The light is so intense coming from the line, I'm afraid to let my 5-month-old daughter look at it when I'm trying to figure out what's wrong.
  • 4,234 Answers
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Posted on Feb 24, 2009
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Jun 30, 2009 | Sanyo DS31590 31" TV
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
Apr 18, 2009 | Sanyo DS27820 27" TV
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Bad picture on Toshiba
this is a malfunction vertical deflection block of your TV-set .please contact the nearest repair not turn it on until then,please.
Apr 17, 2008 | Toshiba 36A40 36" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Sanyo DS31590 31" TV Logo
162 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
