Question about Logitech Quickcam IM 961361-0403 Webcam
My mic makes me sound like a man
Can u fix it
Radio worked fine when bought 2 days worth went to key up mike only sound is a sustained whistle sound,took to repair shop had fixed guy said he rebuilt talkback worked again 2 days same result sustained...
Do it have a relay mod for the talkback if so take that thing out. use the normal talkback. We are in TX.. no charge to check out.. I would check to make sure it has just plain normal talkback, and no other mods done first.. any other mods done??
Mar 19, 2011 | Connex Radio Communications
Im not sure if its a mic problem or an interface(m-audio fast track) or even if its the program im using (adobe audition 1.5) but when i record using the sterling ST51 it sounds like im about two miles...
First, Make sure you are speaking into the front of the microphone. there should be a logo or brand name at the front to show you. because of the cardioid pattern, sounds behind the mic are not picked up; good if the sound you want to isolate is at the front, not so good if it's at the back. Second, make sure the gain on the fast track is turned up. And third, try using a different program. It's unlikely to be the problem, but if it is, it's an easy fix.
Jan 15, 2011 | Sterling Audio ST51 Microphone
I have a DELL Studio 1737 running Windows 7, with integrated web cam. i am trying to make videos with web cam and video is perfect but no sound on playback. Dell webcam central is what i am using to make...
Sounds like a software issue, possibly with webam central. There's a free player that has good codecs, and it may help you. Here it is:
http://www.finalmediaplayer.com/
This will be an easy fix if it works.
Jul 31, 2010 | Computers & Internet
Speakers sound hollow. mic in sounds like squirrel
i think you're driver did not do the right setting for you. try searching drivers from this site http://www.rudytarigan.com/laptop/toshiba-satellite-l310-drivers.htm or search realtex HD manager. They will do all the work for you
Aug 02, 2009 | Toshiba Satellite A355-S6935 Laptop
My array microphone isnt working
i do not believe there is anything you can do... It eitheir your mic. or it could actually be you. You sound different then you hear yourself and that my friend is one way to find out what you really sound like.
Mar 23, 2009 | ASUS M2N-E SLi Motherboard
AKG 414 crackle
Had the same problem. Check the ground (earth) is attached properly to the mic. This will cause the signal to be interrupted and can also cause a phasing problem. A lot of techs don't check that when you send them for repair
Nov 12, 2008 | Audio Players & Recorders
Mic problems online
If your mic is a bluetooth then it could be that your far away from your ps3 when your playing.
Aug 05, 2008 | Sony Resistance: Fall of Man
Sounds like a pulse or heart beat
u try new cable 1st take bass down effects ect gain on it cheak polirty of it
Jan 27, 2008 | Shure KSM27 Professional Microphone
Only on one side
cheal faders balence on the mixer ect is that unit phantom powered ready also
Jan 27, 2008 | Tascam US-144 Sound Card
Logitech Quickcam IM 961361-0403 Webcam Logo
299 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
