Question about Philips 42PF9630A 42 in. Plasma Television
Tv wont turn on, red blinking light by the power light. How do I fix this?
    Scholar:
  • 73 Answers
Plasmas can be a little tricky to diagnose. If you are comfortable with dismantling the TV and doing some multimeter (voltmeter) testing then, here's what to try. I need to express to you that what your are about to do can seriously hurt you if you aren't careful, The boards on plasmas can hold charges HOURS after the TV has been unplugged. DON'T FUMBLE AROUND! If you aren't comfortable using a mulitmeter to check for faulty circuits, then call the local repair guru. But if you're willing to learn something new and get that feeling of self accomplishment I'll help out in any way I can. This is going to be a long repair instruction aid:
First use a thick cloth or blanket on a clean work bench or table that you don't mind occupying for a few days. Lay the TV face down on the cloth with the stand hanging off the table. Remove the stand and position the tv for stability. Next, take the back off. There is about a million or so hex screws holding it in place on this model. Keep track of these screws, not necessarily where they all go, because they're all mostly alike. Once the back is off you will see five large rectangle circuit boards or different sizes, and four long skinny boards. Starting from the left side of your view you will see two long skinny vertical boards attatched to eachother and to a green board with a large heat sink they have 3 orange ribbons attatched to each one. Those skinny boards are the Y Buffers. The board they are attatched to is the Ymain or the YSUS (Y sustain). Next is a small board behind a silver tray holding the signal board. The signal board is easy to distinguish because it has all the input connections on it. Behind that one is the Logic Main. The largest board that is almost directly in the middle is the Power Supply Board, or the PSB. To the right of the psb is the XSUS. Along the bottom of the tv are two long skinny horizontal buffers that operate from the X sus.
You need to start with the PSB. Usually near the xsus is a visible sticker with voltages displayed. They coorespond to things like Va Vs Vsc etc. All of these voltages can be checked on the PSB. Look carefully at the PSB particularly to where the cable that connects the psb to the y main. Each of the terminals is labled. Its been a while since I've seen this particular board but often there are test points that coorespond to each of the voltages given on the sticker. Using your multimeter on the dc 200 setting, check to see if all your voltages are close to spec. If they are slightly, and by slightly I mean + or - 2 volts, that is ok. If they are any further off than that but not drastically off, there are adjusters for each voltage somewhere on the PSB. They look like plastic phillips screw heads in a 1/4 square metal housing. with your meter grounded to the tv safely, adjust these to find the correct voltage. DO IT SLOWLY, like GRANDMA IN MOLASSES IN MICHIGAN IN DECEMBER SLOW! If one of the voltages is severly off, replace the PSB and fire the tv up. You can try to rework the board, but trust you me, its not worth the time, risk nor effort involved. IF all your voltages are ok, then move on to the next likely problem. The Ysus. This model was made with samsung and LG parts and tv's from those makes also are plagued with this problem. The Ysus is most likely the problem anyway. They have a horrid tendency to burn out and to take the buffers with them. I recommend you replace all three. I don't know a sure fire way of testing this board accurately so you'll just have to take my word for it. The cheapest place I have found to have these boards replaced or repaired is on ebay, there is a seller with the tag of superdog**(something) and his name is Tri Nyugen. He lives in so cal somewhere and is where I send my parts (I've had two different tv's with these exact same innards, one was a phillips, the other a samsung, with IDENTICAL problems, the Ysus and the buffers). He does a great job and has lightning fast turn around. Tell him Captain_Axle sent you. Replace all three boards at the same time. If you don't you'll burn the new ones out quick. I am 99.99% positive that your TV will be up and running after replacing these boards. If its not, post another comment and I'll continue with the repair novel. Feel free to email me directly for help. Cfoley@hawaii.rr.com
Good luck.
Posted on Feb 25, 2009
  • Axle80
    Axle80 Feb 25, 2009
    Just to clear which three boards I was taking about in the end there, the two skinny Y buffers and the ysus. You can get the part numbers off the boards themselves. You will have to remove the large screen brace to get access to the Ysus. Even then its a bit snug when taking it out.
4 Suggested Answers
Agent Aaron
  • 265 Answers
SOURCE: red blinking light
Hey ojustgowithi,
While this blinking red light may indicate a potential hardware problem, it may just as easily be the result of a built-in protection to prevent the TV from being damaged by power surges. To determine if this is the case, I would suggest unplugging the TV and all connected devices for a few minutes. If the TV operates normally once you've plugged everything back in, the unit may only have needed to be reset.
You may also wish to refer to your owner's manual documentation and troubleshooting FAQ for more information. Some model TV's will have error codes listed in the owner's manual that are dictated by the number of times a given light flashes on the front panel of the TV.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 24, 2008
SOURCE: Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Posted on Sep 07, 2008
SOURCE: My panasonic 42" plasma wont turn on, but the power light blinks
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on Apr 17, 2010
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Fix red light flashing
need the make and model number..the red flashing may be a blink error code
May 23, 2015 | Televison & Video
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Tv lights blink, tv not turning on
HI, the fly back transformer has failed in your unit. this will occur if the dust level is high inside the set. the dust will settle on the cooper windings and, create an arch that will short out the entire power sector of this unit.
The fly back is usually the first to take the hit. replacing this will fix this issue.
Jul 11, 2009 | Televison & Video
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Philips 42PF9630A 42 in. Plasma Television Logo
853 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
