Question about Xerox Phaser 8500/DN Printer
Xerox 8500 will not recognize paper size
I have had my Xerox 8500 for about 2 years and up until now it has worked fine. Once a month I need to print a form that is 7.33 x 8.50. When I was running XP-32 it worked fine. Since I changed OS to XP-64, the printer will not recognize the paper. It keeps telling me to load the 7.33 x 8.5 in Tray 1 (whihc I have done already) or it asks for 7.33 by 10.50 ???
Any ideas?
Thank you
  • don_chambers Mar 31, 2009
    Well that did something. Not sure if it worked yet since I do not have to print the form yet.
    Thank you
    Scholar:
  • 49 Answers
Hi Don,
Looks like you need to download the driver for 64 bit windows, I believe there have been some issues with 64 but hopefully this will help!
Try installing this driver - Windows PostScript PPD Driver Files - 32/64-bit
Use this link for any further problems with you 8500 -
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_8500_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_8500_8550):str(8500_8550),question=ref(ProdFamily):str(Prod_8500_8550),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:8500_8550,varset=prodName:Phaser%208500/8550
Posted on Mar 30, 2009
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Phaser 8860 says "Maintainance Kit is Missing"
Most likely it needs service. Here is the service provider finder from Xerox.
Aug 24, 2009 | Xerox Phaser 8500/DN Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Xerox 8500 - overprinting when double-sided
That normally is caused by a dirty maintenance kit. Often times they dry out and do not put enough lubricant on the drum, I would start with a new mainteanace lit., you may also have a bad wiper blade, although thats less likely.
Apr 14, 2009 | Xerox Phaser 8500/DN Printer
Command Work Station Software
xerox fiery x12 command workstation downloads
Sep 15, 2008 | Xerox DocuColor 12 Printer
Xerox 8500 not printing
It sounds like you need to check your addressing. Sounds to me like your IP address reset back to default.
You need to go into the network settings and check your IP address and make sure it is set to manual and not auto.
I believe your printer did a reset and your address is wrong.
Jun 27, 2008 | Xerox Phaser 8500/DN Printer
Envolpe feed problem
I would first off try cleaning the feed roll in that tray well. That really sounds like slipping.
Go through all your programs and make sure that the driver machine and program you are running has the envelope settings the same.
Be sure they all match. Example. Make sure all the programs you are running through, have the settings for # 10 envelope, consistancy is needed for running envelopes. They are problematic.
May 01, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
245 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
