Question about Belkin USB Hub
BELKIN NETWORK USB HUB SXUPTP Driver problems
Hi to all who can help:
Just bought Belkin network usb hub (http://www.belkin.com/networkusbhub/) to link some of my ext hard disks. Installed the belkin program and on restart, it prompted me that SXUPTP Driver is missing and asked me to re install. and all this while it sits in the system extension folder. How do i link this file ? I am currently on Tiger, osx 10.4.10.
I downloaded the latest driver for 10.4 from Belkin support website ( http://www.belkin.com/support/article/?lid=en&pid=F5L009&aid=8547&scid=220) but it prompts me the same missing driver file. Out of curiousity and desperation, i downloaded the driver for Leopard 10.5 as well ( even though i am on tiger, guess how desperate i was
)and installed it . It too prompted for the missing SXUPTP driver file? What is going on?
Right now, the hub just sits and looks pretty , doing nothing.
Can anyone shed some light and how do some of the mac users get this hub to work with their machines?
Thanks in adavnce!!!!
J
3 Suggested Answers
steinja66
  • 52 Answers
SOURCE: Blue screen when playing iTunes on Logitech Z-10 speakers
Before, you return it, can you unplug the Wireless USB Hub, and plug in your iPod and does it work just fine?  Also, the USB port that you're plugging it into - is it USB 2.0?
If both answers are YES to the above - then definitely return it.
It's not your speakers.
Posted on Apr 03, 2009
  • 122 Answers
SOURCE: Belkin Wireless 5-Port Hub (F5L009) Problem
If you set the allowed IP address in the security section of the router then you must fix your computer IP to 192.168.1.101 with a subnet mask of 255.255.255.0 the default gateway should still be 192.168.1.1 and when you get in delete the security locking out all but the one address. Good Luck
Posted on Sep 03, 2009
SOURCE: wireless hub
I had the problem that,even though the hdd connected it would fail after a period of time (video streaming or file transfers). Set up was Samsung Q45 running wireless g connected to a belkin draft N Router. 3 other PCs (all g) using 2 different OS (Vista and Mac) had same problem.
Solution after months of searching, problem solved. Fitted Draft n PCMCIA card, and to ensure it was running at 300Mb had to use WPA PSK + WPA2 PSK security mode . Now works brilliantly and has managed to stream a full HD movie!! The Wireless link is now running faster 10Mbs compared with 4Mbs on g, although not fast it at least enables the HHD to be used in a stable configuration. Problem seems to be that the unit will not work properly unless wireless n link is used.
Posted on Oct 27, 2009
Need windows 8.1 driver for SXUPTTP
It is compatible: http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Belkin%20F5L009%20USB%20Hub&vendor=Belkin&Locale=1033%2C2057%2C3081%2C4105%2C16393&BreadCrumbPath=Belkin%20F5L009&LastSearchTerm=Belkin%2BF5L009&Type=Hardware&tempOsid=Windows%208.1
Try opening device manager (Windows Key + X then select device manager from the dropdown) Find your device: Look under "unknown devices" or "universal serial bus controllers", right click and select update driver software.
Nov 07, 2013 | Belkin Components F5L009 5 Port Network...
System error found
Hope this will help someone else:
InWindows' Device Manager (devmgmt.msc), the SXUPTP driver was showing as disabled.Windows gave a warning that the device was known to have stability issues. Ifound out that SXUPTP is a driver from a company called Silex. Silex makesnetwork USB hubs, so I assume that the Belkin hub is a rebranded Silex hub.
In order to update the Silex driver follow these steps:
1. Close the Belkin network hub's tray application.
2. Download the latest version of SX Virtual Link(sx-virtual_link_win_3120.zip).
3. Extract all of the files.
4. In Windows Explorer, navigate to sx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVistaX64if you are running a 64 bit OS, orsx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVista if you arerunning a 32 bit OS.
5. Right-click on "Sxuptp.inf" and select "Install" fromthe menu.
The driver will be installed and the warning icon in the device manager shoulddisappear. You may need to reboot for the changes to take effect.
Nov 03, 2013 | Belkin Computers & Internet
Sxuptp driver (belkin hub) makes XP PC hang with start up PC
I tried many procedures to get this working in Win7 x64 but every time I ran the installation package for the Belkin control center Windows stopped the process and showed there was and error with the Setup64.exe
Then I decided to go to the Silex web site and found a recent version of the Virtual Link software, which is the software the Belking control center is based on. Downloaded it, installed it (with no Belkin crapware installed whatsoever, remove everything Belkin first) and it runs 100%. I can see my printer with no issues. biggrin.gif party.gif
The link to the software page is this >>> http://www.silexamerica.com/support/software/svl.html
They have fairly updated versions for Win and Mac. I hope this helps.
Oct 20, 2012 | Belkin SXUPTP Driver
Belkin F5u234 driver download
Belkin f5u234 drivers can be found at driverupdate us.Take a look, and enjoy
Jun 23, 2012 | Belkin (F5U234V) 4-Port USB Hub
My belkin Hi-speed usd 2.0 7-port hub wont work and i cant find the CD that it said it came with. what do i do?
go to this site and download the driver for it. The CD basically contains the driver software. You can easily get it online.
http://download.cnet.com/1770-2014_4-0.html?query=Belkin+Hi-Speed+USB+2.0+7-Port+Mobile+Hub+-+hub+-+7+ports+-+desktop&searchtype=downloads
just select the correct operating system and install it on your computer. Let me know if you need any more help.
May 12, 2011 | Belkin (F5U237) 7-Port USB Hub
F5U301 - are there drivers for windows 7
It looks like it is an older product and only has a driver designed for Windows XP SP2.
Mar 06, 2011 | Belkin F5U301 4-Port USB Hub
HP psc1350 shows 'E' code when new toner cartridge is installed
you could use a belking usb network hub http://www.belkin.com/uk/networkusbhub/
This plugs into your router then you plug in your usb devices and hey presto, they can all be accessed by any computer on your network.
So I guess the answer is yes if you're accessing your network using wifi.
Nov 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
BelKin can't connect
Apparently not. (http://www.belkin.com/support/product/?lid=en&pid=F5U304-BRN&scid=1). Only thing on the CD seems to be a USB 2.0 driver (http://cache-www.belkin.com/support/dl/p75342_f5u304_mnl_10-06.pdf) based on the NEC host controller, so all you really need is a USB driver for your computer's hardware, nothing specific to the Belkin.
Aug 23, 2008 | Belkin (F5U304)
Wireless USB adaptor not found
Hi zlyman, The Belkin N1 Wireless USB 2.0 Network Adapter might be choosy with what motherboard it is attached to. Pls refer to this similar problem > http://www.fixya.com/support/t201253-not_identify_belkin_n1_wireless_usb Hope this be of some help/idea. Post back how things stand or should you need further information. Good luck and kind regards.
Oct 02, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin USB Hub Logo
2,767 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
