Question about Mr. Heater Model MH12TS - Single Tank-top Propane Heater
Tank-top propane unit won't stay lit
Portable tank-top heater (for 20# tank) lights for a moment but then makes very loud air-fluttering sound and flame goes out. Has to be shut off or vertical tube heats up in a very scary way.
  • Vernon B. Wingo Feb 24, 2009
    So I need to remove the regulator...Do I take it apart and replace the filter or just replace the whole regulator?
  • David Shaub May 11, 2010
    There is a filter in the screw in part of the regulator. It looks like brass shavings. If it gets clogged, it won't allow enough gas pressure to keep the fire on the catalytic burner. It needs replaced.
  • 2,976 Answers
I had to replace the regulator. If you have a propane appliance shop near you, you can probably just get the nipple that goes into the bottle. It's aboit 3/16" diameter, 3/4" long and may have a 6 sided end up inside the screw on cap of the regulator.
Posted on Feb 24, 2009
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
My reddy heater RLP 100 would not stay lit after I released the ignitor switch so I changed the thermocouple and, the thermal unit switch. The heater will ignite but when I release the knob the flame goes...
A couple of things come to mind:
Restricted air flow. Check heater inlet and outlet. Remove any obstructions.
If the heater has been used in a dusty environment, it may simply need a thorough cleaning.
Inadequate propane supply. Make sure there's enough gas in the tank to facilitate combustion.
If the tank is full, turn of the tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve on very, very slowly, until it's fully open and try relighting and operation of the heater.
If you have misplaced your Owners Manual, you can find it at
Hope this helps to solve your problem.
Mar 02, 2011 | Reddy Heater RLP100 Portable Forced Air...
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
Jan 30, 2011 | Mr. Heater Mr Heater Portable Buddy...
When commected to 20 lbs tank the pilot light does not stay on; however, when connected to a 1 lb propane bottle everything works propertly. I have replaced the fuel filter, I have tried using different...
The new 20lb LPG cylinders now have what called an OPD Valve. Reconnect to a 20lb cylinder and turn the tank valve on very very slowly, This will help prevent the OPD Valve from locking up the heater's regulator. Your 1lb cylinder is not required to have this OPD Valve.
By the way, this happens quite frequently with LP Gas Portable Grills.
Jan 25, 2011 | Mr. Heater Mr Heater Portable Buddy...
I bought the tb100 30K-55K propane heater I hooked it up to a fully filled 20 pound (5 Gal) propane tank and it ran fine for about 45 minutes then the burner shut off. I restarted the heater per the...
Make sure that the thermocouple is well into the flame. Check to make sure the other end is secure into the gas valve. Check for any poor connection both gas and electric. If the LP cylinder is icing up, it is a vaporizing problem and the heater is sucking the available gas out of the cylinder faster than it can vaporize. You will need a larger cylinder.
Nov 25, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Rlp 30 won't stay lit after holding control button 30 seconds
Chk and make sure the thermocoupler bulb is in the pilot flame, If it is, it is defective and needs to be replaced. Easy, inexpensive repair. Good Luck, Ned
Dec 27, 2008 | Reddy Heater RLP100 Portable Forced Air...
Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
Mr. Heater Model MH12TS - Single Tank-top Propane Heater Logo
2,150 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
