Question about Samsung VP-D361 Mini DV Digital Camcorder
Samsung digital-cam sc d453 ntsc the tape ejects and will not do anything
  • 35 Answers
The transport is bad.. need a new deck
Posted on Jul 31, 2009
5 Suggested Answers
charcois
  • 763 Answers
SOURCE: Samsung SC-D363 Mini DV digital camcorder
sir if your camcorder is new then it has a warranty. we should send it first for their service because they have a spare parts for replacement and info. if your going to fix it by yourself then the warranty of that will be void. by the way the place for the service center for camcorder samsung in the philippines is in makati i think. i got a problem with my samsung just like your model and they told me that it is located at makati. hope that helps!
CHARCOIS
Posted on Oct 03, 2008
z89s
  • 225 Answers
SOURCE: hi i have videos recorded on tape with my samsung
mini usb cable also depends on what inputs your camcorder has but most of them have mini usb inputs then use windows movie maker to put it on the computer if you dont know what cable to get then just take it to the store and they will tell you what cable you need
Posted on Jul 30, 2009
  • 72 Answers
SOURCE: Samsung SC-D365 Digital Video Cam user manual
On the internet call up :
http://www.samsung.com/us/
Then in the upper left of the screen labled "Find" type in "SC-D365". Then click on "Users Manual" . You'll have to be able to download a PDF file.
Posted on Dec 01, 2009
tbreeze47
  • 3083 Answers
SOURCE: Need copy of owners instructions of use ect. for
Here is a copy of your manual at this site:
http://camera.manualsonline.com/manuals/mfg/samsung/samsung_sc_scd453.html
Hope this fixes you up, and thanks for using FixYa.
Posted on Sep 04, 2010
Dear Fixya, I'm problem with my mini-tape dv rollout or spitting out while loading on Samsung camcorder SC-D453 any solution?
sir,
Please use a contact cleaner spry,
eject the mechanism, take the cassette out, look at the left below side of the eject mechanism, you can see the mode selector switch lays there. (may be not clearly visible) just point the nozzle of the contact cleaner spry to that direction spray a little, then let it dry for a while, connect the power, on it, put the cassette in and ply it.
this will cure most of the similar problems.
Jan 20, 2016 | Samsung Video Cameras
Rejecting tapes
I had the same problem with my SC-D363. My screen would flash "D" and tell me to eject the tape.
Here is the SOLUTION:
1) Very Gently unscrew (4 screws)and remove the front casing portion of the camcorder, be sure not to strip the screws.
2) Directly underneath the lens there is crosslike metal support that extends from the tape
compartment chassis. The green circuit board should rest on top of it as shown below instead of
underneath it, as it was when it was assembled.
And Voila! Camera works like when it first came out of the box.
Custom Car Parts
Jun 06, 2012 | Samsung SC-D453 Mini DV Digital Camcorder
Samsung mini DV sc-D366 always displays eject
I believe your problem is in the drum motor assembly part No is AD97-10579A. Samsung they know that problem it require a Technician to replace this part because you must adjust electronic and sometime mechnism as well. Depend which country you are it might cover under warranty even your CAM is out of warranty just check with Samsung in your area
Dec 04, 2008 | Samsung SC-D33 Mini DV Digital Camcorder
CHARCOIS
Oct 03, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D103 Mini DV
sounds like your tape transport is bad.. something might of broke inside since it almost all plastic.. try to run a dry tape cleaner through..
Aug 28, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Flashing protection, icon ..R
Mine was doing exactly the same, driving me nuts... Finally, I was trying EVERYTHING, and went into the menu and set the clock and date. I put the tape in, pressed it down where it says to press, the tape loaded normally and As oddball nuts as it sounds, it immediately began to work like normal. I havn't been able to get it to do anything but eject and flash that stupid "R", for months. Hope it helps...
Mar 18, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Pal on SC-L700
This model will play only NTSC. NTSC is the television broadcast system used in the USA (and a few other countries) Tapes of any format than NTSC will not play properly in this camcorder.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung VP-D361 Mini DV Digital Camcorder Logo
224 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
