Question about Zenith Televison & Video
No picture, only a horizontal line across the screen
When I turned on the set, the only picture I got was a very narrow horizontal line running across the screen. I did get sound. There was also an electrical odor.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem indicates failure at the vertical deflection circuitry. Almost always, this would be a defective vertical IC. In some instances, this could also be caused by the absence of Vcc (supply voltage) to the said IC. This is a relatively easy/quick repair. What would be more challenging is identifying the IC, removing it, and replacing. Replacement would be readily available from most electronics part stores including Radio Shack.
Good luck and thank you for using FixYa.
Posted on Feb 24, 2009
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Model CF27C30 - picture consists of one narrow horizontal line across middle of screen
Hello; This is an older 27 " CRT set that has no vertical sweep. This is likely caused by a bad vertical output IC or cracked solder connections on it. It can also be caused by bad capacitors or other components. Some of these sets have an internal "service switch" to set CRT beam currents. If someone has had the set apart and set the switch in the service position, you will get the one H line. Just put back to normal and pix will be back. John
Jan 27, 2011 | Toshiba Televison & Video
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
The picture is smashed down to a narrow horizontal line
Check solder on the vertical output or change it. Dont know # but look for IC screew on heat sink with about 7 to 14 pins.
Apr 28, 2010 | Jensen TS2050J 20" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Televison & Video Logo
226 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
