Related Tags:
This problem should be removed because:
Problem with Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200)
How to configure my paradyne 6381 router<br />
Solutions (1)
Go under LAN setup and enable NAT and Firewall services. Then go to LAN configuration to enable the dhcp server. Set the Start IP range and ending address.
Suggested Solution (3)
You don't -- the strength of the transmitter inside the unit is what limits the signal-strength out at 300 meters.
Instead, you need a "repeater" -- some people have built their own, using a Linksys router, and then reprogramming it with the free 'DD-WRT' software, and configuring the device as a repeater, rather than as an Access Point.
Source: network extender
To configure your router, open your web browser. Type the default IP address (http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge...
I have 6381-A3-302 router when it is switched on then ping shows request time out while LAN status light remains solid green. I have also...
trying to set up pptp on a Paradyne 6381
Everytime we try an connect we get error 800, cannot reach server. We have opened vpn for each pc on the lan, and we are using static ip.
what is the ip address of paradyne 6381 a3 300
what is the ip address of paradyne 6381 a3 300 router
The combined Paradyne router and
The combined Paradyne router and DSL modem, model 6218-12-200 WIFI W/BC is no longer working wireless. How do I replace it?
Add Your Solution
I need to download the
I need to download the usb drivers for the paradyne 6381 modem for windows 7. it does not automatically pick up. what...
my paradyne 6381 is not
my paradyne 6381 is not responding want to upgrade firmware
i got windows 7 it
i got windows 7 it not work with this sistem.
I have a Paradyne Model #: 6381-A3-200 & this
I have a Paradyne Model #: 6381-A3-200 & this morning the Status light won't come on except Blinking. I've unplugged...
See all Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200) Problems
Fix-O-Meter
532
532 people viewed this problem
- 0 people are following this problem. Be the first!
Top Paradyne Router Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
