Question about Intel DG31PR Motherboard
After powering on system automatically goes to BIOS after if i save & exit the BIOS it is showing msg,that is "Turn off the power & reinstall the jumpers in proper mode. Please help me.
    President:
  • 1,901 Answers
There is a block of 3 pins that control your BIOS on the motherboard.
See page 53 of the manual. Here is a link if you do not have the manual.
Intel DG31PR manual
Make sure the jumper is on pins 1 and 2 when you boot the next time. It sounds like they are on pins 2 and 3 now.
NOTE: Remove all power before changing the pins. Turn computer off. Remove power cord. Press and hold power button for 5 seconds.
Posted on Feb 24, 2009
How do i reset my toshiba satellite a105-s2201
Try to open the BIOS, when you turn it on press TAB. Then read witch is the setup key and press it. Its usually "Delete" or "F2" keys. Then if BIOS screen loads, search for the "Exit" options, there you can choose to "Load Setup Defaults", press enter on it, then you can "Save and Exit" (or press F10) and say yes to save changes.
If the problem was solved then it was wrong bios setup. If not, then you need to reinstall the Operating System or check if Hard Disk drive is faulty.
Mar 21, 2017 | Toshiba Computers & Internet
How do i restore my lenovo 3000 back to factory settings. i have no disks that came with it
Power on the computer and during bootup holding onto F2 key will lead you to BIOS. Browse to Intel AMT. Change the settings to "Disable". Save the settings and exit. After the BIOS settings are saved the system will automatically reboot.On the power on you will see a message do you want to continue.Select yes.You will need to enter Bios again. Browse to Intel AMT again change the settings to "Enable".Press exit saved settings.After the BIOS settings are saved,and powering on the system you will have to press ctrl-P to configure ME/AMT again.Hope this might help.
Aug 18, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
When i press the power button the VAIO logo shows then a Intel logo after that there is just a blank screen and windows wont load. what should i do?
Upon starting go to bios settings, click "F2" to access the bios, go to to exit, choose "Default Maximum setting", save upon exit....restart.
Hope that helps you out, msg. me is there are still problems.
Thanks for asking FixYa!
Aug 15, 2011 | Sony VAIO VGC-RA840G PC Desktop
How do I reset it? Joekall@optonline.net
Turn the computer off.
Turn the computer on.
When it shows "press <BLAH> to enter BIOS SETUP mode",
press the <BLAH> key.
Select 'Load BIOS defaults'.
Select 'Save & Exit'.
If that resets it, stop here.
Disconnect the AC power.
Open the side-panel on the desktop case, and look for the 'RESET CMOS' label,
close to three gold pins that are in a row. A jumper will be connected to pins #1 and #2.
Move the jumper to connect pins #2 and #3. Count to 30.
Move the jumper back to re-connect pins #1 and #2.
Connect the AC power.
Jan 05, 2011 | Computers & Internet
Keeps shutting down.
To resolve the issue, Please perform the following steps:
Step 1: BIOS Reset
To reset the BIOS defaults, follow these steps:
1. Restart the computer and press F2 (F10 in some Notebooks) as soon as the HP logo appears.
2. Go to Exit menu and select Load BIOS defaults or press F9.
3. Go to Exit menu and select Save changes and Exit or press F10.
This will reset the BIOS defaults. Now, when the Notebook restarts, press F8 repeatedly until the start up menu appears. Select the Safe Mode and press Enter Key to enter in Safe Mode and then perform the step 2.
Step 2 : Disable the "Automatically Restart" under System Failure:
1. Click Start, right-click the My Computer icon, then Properties.
2. Click the Advanced tab, then Settings in the Startup & Recovery section.
3. Remove the check mark next to Automatically Restart under System Failure.
4. Click OK to close the Startup and Recovery window, then click OK to close the System Properties window.
5. Restart the computer.
Step3: Reinstall Power management
To reinstall Power Management in Windows XP, follow these steps:
1. Click Start, select Control Panel, and then choose Performance and Maintenance.
2. Click the System icon to open the System properties window.
3. Select the Hardware tab and click Device Manager.
4. Click the plus (+) sign next to System Devices.
5. Right-click the ACPI Fixed Features button and select Uninstall.
6. Restart the system.
On restarting the system, Windows will automatically detect and install Power Management on the computer.
May 25, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Turn off power and reinstall the jumper in normal mode position
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
SYSTEM PROBLEM
Hi!Good Pm...Hope this will help...
Maybe your operating system was corrupted or some of your hardware is causing the problem...Hardware issue?Try troubleshooting by disconnecting the hard drive,cdrom & floopy drive.Power on with the motherboard,processor & memory only.Does your system boot?Enter the bios & load to setup defaults or bios defaults.Save & exit...Turn off then connect the HD,CDR & FDD.Power on again then see what happen...Software issue?Format your hard drive & reinstall new operating system...
Jan 29, 2008 | Intel D865GBF Motherboard
Intel DG31PR Motherboard Logo
122 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
