Question about Bernina 1008
How do you thread a bernina 1008?
I cant figure out how to thread my new bernina 1008 sewing machine i got for xmas and i have lost the manual can someone tell me step by step how to thread this machine!
  • gooodtimes Sep 28, 2009
    pajina, i was wondering why you placed **** in the middle of paragraphs, im using this and i can;t figure it out? what do they mean?
  • 30 Answers
I hope I can explain this in an understandable way!
1. Pull the end of the thread from the spool to the left and "click" it into the little metal guide (on the top of the machine) that is at the back of the long **** in the top. It's easiest to do this by holding the thread tight between your two hands, placing it behind the guide, and pulling forward until it clicks in.
2. for the remaining steps, let the thrread slide between the fingers of your right hand, keeping a little tension on it, as you thread the machine with your left hand.
3. Bring the thread end forward, laying the thread into the ****, and continue downward, along the right side of the vertical silver bar/hook thingy.
4. Bring the thread under that bar from right to left, and go back up towards the top of the wide **** in the front of the machine. As you pull up, the thread will click into the lower bar/hook thingy.
5. Lay the thread along the right side of the wide ****, go over the top of the needle bar (the part that goes up and down in the ****) and bring it down the left side. It will click into the needle bar.
6. Bring the thread back down towards the presser foot. Right in front of the screw that holds the foot on, there is a hook that opens on the left side. Slide the thread behind this hook, and then thread the needle from front to back.
7. Hold onto the end of the thread and run the needle down and back up once. Pull on the thread, and it will pull up a loop of the bobbin thread. Stick the tip of your scissors or seam ripper into the loop and pull the end of the bobbin thread out.
8. Slide your top thread through the slot in the presser foot so it comes out from underneath the foot, and you're ready to go! (Be sure and hold onto both threads for the first few stitches when you start a seam, to keep if from jamming up inside.)
Let me know if you need any clarification.
Posted on Jun 21, 2009
I need to thread a bernina 2000DE I would like to see a picture
try sewusa.com they have threading diagrams
Nov 27, 2010 | Bernina 1008
How do you CORRECTLY thread a Bernina 1008 for a double needle
Hi
Do you have a manual?
If not, manuals can be found on the Bernina site.
I found one for the 1004 or 1005 and another for the 1011. Hopefully one is similar enough to your machine.
http://www.berninausa.com/webautor-data/486/BERNINA_1004_1005_manual.pdf
http://www.berninausa.com/webautor-data/486/BERNINA_1011_manual.pdf
Hope this helps!
Sep 23, 2010 | Bernina 1008
How to set my Bernina 1008 sewing machine up for sewing
That information is in the instruction manual that's available here:
Bernina 1008 Sewing Machine Instruction Manual
Dec 01, 2009 | Bernina 1008
I have a Bernina 1008 and I love it, but every time I try to sew with it lately, the bottom thread wads up and makes a terrible mess. It will sew OK for a little bit and then the bobbin thread sort of...
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Rick
Sep 30, 2009 | Bernina 1008
Bernina 1008 sewing machine making huge clumps of loops on underside of fabric. have tried moving screw on bobbin in two opposite directions without a sign of improvement.
Hi: You have threaded the machine incorrectly. Rethread the machine with the presser foot up to the needle, pull the thread (loose) and drop the presser foot while pulling thread, thread should get tighter, then thread needle and machine will work fine. Make sure the top tension is set at where you normally have it, probably about #4 or #5
Jan 08, 2009 | Bernina 1008
Threading a bernina serger
Here is a little jingle to remember as far as the order of threads to thread...
Upper looper, lower looper, left needle, right.
Usuall if you give numbers to the threads from left to right as 1,2,3,4 , you would thread it in the order of 3, 4, 2, 1 . Also when threading the loopers be sure the lower looper thread goes over the top of the upper looper thread as it goes out the back.
Hope this helps.
Sep 02, 2008 | Bernina 1008
Parts
Contact a Bernina dealer as Bernina Switzerland produce a series of charts for schools showing machines and overlockers. With full threading and machine descriptions.
Jun 19, 2008 | Bernina 1008
Sewing Machines Logo
1,349 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
