Question about Onkyo TX-R805 Receiver
Onkyo TX-805 7.1 fails to power up out of standby
Same problem as above. Onkyo tx-8511 wont power up out of standby
  • 6,784 Answers
Hi, this can happen during a surge or circuit breaker issue. the stand by mode is also a power protect mode in this situation. im afraid the surge has fried your capacitors on the power board. this will require repair by a skilled tech.
Posted on Feb 24, 2009
  • Michael Masters
    Michael Masters Feb 24, 2009
    Hi again, There is a safe guard that may have saved your receiver. This unit has an A.C. fuse inside that may have absorbed the surge hit. replacing this A.C. fuse may bring it back.
How to connect Sony dvd player to onkyo TX-8511 receiver
The TX-8511 is an older AV receiver with only composite video inputs. Your DVD player may not provide this type of output as it's not capable of HD video. If your dvd player has a composite output with a Red, White & Yellow set of outputs, that will connect into the Video 2 inputs on the receiver. Your TV will need to connect up to the Video2 or Monitor output. You'll need a set of composite video cables with the red-white & yellow RCA type plugs.
Here is a link to the manual for this receiver:
Receivers Receiver Stereo Receiver AVR TX 8511 Onkyo USA
Mar 13, 2015 | Onkyo TX-8511 Receiver
How do I connect my Samsung Model un46b8000xf led to onkyo receiv
Use the TOSLINK - the optical/digital connector on both devices.
Jul 07, 2010 | Onkyo TX-8511 Receiver
I must have hit some buttons on the remote unintentionally - all of a sudden I lost the sound out of the left speakers on my Onkyo TX-8511
Reverse left and right speakers at back of unit
to verify if a speaker/wire problem. Also check
all functions for same problem!
Jan 30, 2010 | Onkyo TX-8511 Receiver
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
the unit has sensed an internal fault and shut down or the start up relay has failed in pin #3 inside the unit you will need a service tech to help, if its new the unit is under warranty, the other common cause can be a speaker short in the back, in the wiring or worse at one of the speakers, my new unit had the same problem twice, once for the relay and once because the unit error self test did not like the unit in 6.1 configuration with the left rear surround speaker, holding the power knob down on start up for 10seconds kicks in the auto self diagnostics mode good luck
Jan 19, 2008 | Onkyo TX-R805 Receiver
Power up problem
try powering the unit right down by disconnecting from the mains supply. fire up after 5 mins and see what happens. There is a separate transfomer for the standby supply(small red light) An internal fuse may have failed or the thermal fuse inside the transformer. If fuses blow as sson as you fire up = output transistors hay be short circuit.
Dec 07, 2007 | Onkyo TX-8511 Receiver
Onkyo TX-R805 Receiver Logo
385 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
