Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
Keyboard not functioning
My computer here is not functioning as when I log in, the keyboard just turn off and could not function.It turns on when you switch on the CPU but then all of a sudden it turns off again. It seems funny as the mouse is functioning but not the keyboard.Both the mouse and keyboard are USB cables.I have tried the other keyboard but still no change.
  • 66 Answers
Usb mouse and keyboard depend on ur usb ports and ur bios u should check that ur usb drivers are installed properly or not .n try changing ur keyboard in different usb port . thanks
Posted on Apr 20, 2009
How do I turn of the short cut and switch to standard F function on the Macally usb Mac Keyboard
If you prefer the top row of keys to always behave as standard function keys without holding the Fn key:
  1. Choose System Preferences from the Apple menu.
  2. Click Keyboard.
  3. Click the Keyboard tab if it's not already highlighted.
  4. Select "Use all F1, F2, etc. keys as standard function keys"
Oct 11, 2017 | Macally Computers & Internet
Third function keyboard
The purpose of a laptop's function key is to activate the secondary function of any dual-purpose key.
The function key can accidentally be locked into place if you hit the wrong combination of keys so that all of the keys only perform their secondary function.
The exact process for unlocking the function key will vary depending on the make and model of your laptop and whether you have recently used an external keyboard.
Check the manual that came with your laptop and locate the section on the function of each keyboard key.
Open a Web browser and navigate to the support section of the laptop manufacturer's website if you do not have the manual that originally came with your laptop.
Use the drop-down menus on the support page to choose the specific product line and then model of your laptop.
Click on the "Product Support" link and then navigate to the "Manuals" section of the page. Click on the link to open a PDF version of the manual for your laptop.
Browse down to the section about the functions of the keyboard keys.
Find the sequence of keys you need to press to unlock the function key on your laptop.
Press and hold the function key on the keyboard and then press the other keys required to unlock it.
Try using the most standard keyboard combinations if you don't have the manual or it does not give any information about the function key.
Press the function key and then the shift key and see if it successfully unlocks the function key. Attempt using the other standard keys in conjunction with the function key, such as the "F11," "F12" and "Ctrl" keys.
5
Plug a USB keyboard into the USB port on your laptop if you have recently used an external keyboard with the laptop.
Check the light above the "Numlock" key on the external keyboard and see if it is turned on. Press the key and make sure the light is turned off and then remove the keyboard to unlock the function key.
http://us.acer.com/ac/en/US/content/support
Acer Support
Nov 26, 2013 | Acer Computers & Internet
How do i turn on my wireless keyboard
1 Follow the steps mentiond below:
•2
Leave your current wired keyboard plugged into the computer. Many computers will cease to function if their keyboard is removed.
•3
Make sure that the computer is on and is functioning properly.
•4
Plug the USB wireless adapter of the wireless keyboard into a USB port on your computer. If you don't have a USB port, then your computer is probably too old and likely won't support a wireless keyboard.
•5
Make sure that there are batteries in your wireless keyboard. Oftentimes, the consumer is responsible for putting the batteries in, and they don't come with the keyboard when it's purchased.
•6
Turn the power on for your wireless keyboard. The method of doing this varies depending on the model you've purchased, but the power switch/button is generally located on the bottom of the wireless keyboard.
•7
Wait for the keyboard to download it's driver software. If you don't have a connection to the Internet, use the software that was included with your wireless keyboard to install the driver manually.
•8
Use the wireless keyboard exactly as you would a wired keyboard.
Aug 31, 2010 | Computers & Internet
Sony vaio laptop is turning on but the keybord+mouse not working
If your Keyboard and mouse are PS2 type, turn off your system, unplug them and try a USB type mouse and keyboard instead. If you are already using USB type mouse and keyboard, then try plugging them into different USB ports. Bootup in Safe Mode if possible. If you do not have keyboard functionality during the initial boot process, you may have sustained damage to the motherboard. The fact you mentioned a noise (speaker type?) and then lost component function, would indicate a possible hardware failure
Apr 14, 2010 | Computers & Internet
Keyboard on toshiba satelite laptop does not work
“To find “Enable” the “Keyboard with your system.” You can do the following: Shutdown the Computer, connect the Keyboard to your computer.
I. Turn on the computer. If the “Keyboard have a Power Button?” (Turn on) the keyboard.
II. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers!
III. Click OK. Restart the computer. Check keyboards’ functionality.
Did this solution help?
Jan 28, 2010 | Toshiba Satellite A105 Notebook
Keyboard stopped working completely.
To, Fix the problem, do the following. Shutdown the Computer, Disconnect the keyboard from the computer, and unplug AC (adapter) from power outlet. Reconnect in reverse order. Turn on the computer. Turn on the keyboard. Go, to Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to "Update Drivers!"Click OK. Restart the computer. Check keyboards’ functionality.
Jan 17, 2010 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Keyboard aint working
Hello there:
You may want to try it in a other computer also see if a nother keyboard will work on the computer and see if it works.
If so turn off the computer and reinstall the keyboard and try to reboot and see if all of the keys work now. ok? if you have the cd that came with the keyboard. ok i hope that this is very helpful for you please dont forget to rate these solutions for me cause it helps me out too .
best regards
MICHAEL
(UNITED STATES NAVY RETIRED)
Aug 22, 2009 | Computers & Internet
Scroll lock light is on.keyboard keys will not function, cant log on computer. how to turn off scroll lock, as toggle. if hotkey has been assigned to scroll key, I am not aware of the key sequence to...
Is this on a laptop or desktop PC? Does the Scroll Lock button not toggle the Scroll Lock LED? Make sure the keyboard is plugged in all the way, and is not plugged into the mouse port (if it's ps/2 and not usb)
Jul 17, 2008 | Belkin Computers & Internet
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
180 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
