Question about Bose Companion 2 Computer Speakers
Speakers only play cd's
I have a new XPS 630 and bose companion II speakers. Speakers play fine with cd's but no other sounds are working. Trying to play music from internet or radio I get no sound. Everything is plugged in right and I can find no mute checks on anything. Any help is appreciated. Thanks Bonnie
    Problem Solver:
  • 8 Answers
Please look in your Start Menu, go to Control Panel, then into Sounds, Speech and Audio Devices. See near the left, and select Advanced Volume Control. Turn up the inputs for the other sounds that you want delivered out to those speakers. Later adjust the levels a little higher if at first the mix of the sounds is not quite loud enough from one or several of the sound sources. Also in Control Panel, Sounds, you can mute out or eliminate annoying unwanted system sounds such as sounds for minimize and maximize a computer window, and the click that occurs when the computer does Complete Navigation -which it does a lot. Go into Sounds and Audio Devices, and into the Sounds tab. Select the Windows Program event such as default beep and click pick NONE from the sound chooser scroll bar that is just below. Scroll up to NONE to eliminate that sound. Now your overall sound experience will be more pleasant, without unneeded sounds playing loudly, unexpectedly.
Posted on Feb 24, 2009
Hi _ I got a new set of Bose Companion 5 - is working fine with my PC Windows Xp service pac II. suddenly the speakers go off wehile playing music & I have to restart the comp to hear music ?? Cant...
Try another set of speakers to eleiminate the BOSE speakers as being the issue (even cheap ones will do). If the problem does not re-occur, the issue is with the speakers.
If all the speaker jacks are plugged in correctly, I would consider returning this set, as it looks like the issue is within the circuitry of the Woofer
Jan 01, 2011 | Bose Companion 5 Multimedia Speaker System...
Hooked up my Bose companion 3 series II speakers but cant get sound. Which input hole do I put the audio cable? I put in the speaker jack that the original ran off of but its isnt working I have a dell xps...
Hi there , and happy new year ... The Cables are usualy Colour Coded , so try plug the Green Color coded Wire into the Green Jack Socket ...make sure it isnt connected to the Microphone socket..
Hope this Helps Bud
Have a Great Year: )
Dec 30, 2009 | Bose Companion 3 Series II Multimedia...
Bose companion 2 speakers not working with the HP slimline
Speakers are speakers. They should not need configuring if they are funtional and powered up. The speaker out jack does not know the difference from bose to sparkamatic.
Aug 31, 2009 | Bose Companion II Computer Speakers
BOSE speakers won't work with my HP Pavilion Desktop......help!
try reinstalling the software for them then make sure your sound card drivers are installed properly
Aug 10, 2009 | Bose Companion II Computer Speakers
Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Feb 11, 2009 | Bose Companion 2 Computer Speakers
Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Dec 26, 2008 | Bose Companion III Computer Speakers
Bose Companion 3 Series II not working (Mac)
The speakers seem to be muted by default - you'll see that the LED is yellow/amber. Tap the control pod - the LED will turn green and speakers will work. I felt like such an idiot after I spent almost an hour trying to figure this out. (This feature should be more prominent in the manual.)
Dec 20, 2008 | Bose Companion III Computer Speakers
Bose Companion 2 Computer Speakers Logo
163 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
