Sir, I have seen your advice in yahoo answers, so i am sending this mail to you I have Samtron 45Bn Monitor with Intel mother board CPU. I connected these two devices with 0.5 KV UPS. I switch on the system it turns on windows operating system turned up. During the operation inside the monitor their is a sound like"Chirk Chirk Chirk" I suddenly switch of the UPS. then later i switch on the UPS and switch on the monitor button but the power LED light is not light up. and monitor not working. the cpu is working but monitor is not working if i connects with the power and switch on the monitor the led light not light up and monitor not on so please kindly give the solution regards
SOURCE: Open cover of Samsung Samtron monitor
remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
SOURCE: HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command.
Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help
This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
SOURCE: Sir help Me with my Compaq MV520 monitor the power led flashing orange to green and vice versa
Hi..there! Sir Neil:
You're right... Your backlight inverter are busted. Need to replaced a new one or repaired it.
SOURCE: Monitor flickring
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
SOURCE: I have lg flatron l1730s
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display.
