Question about HP PSC 1315 All-In-One InkJet Printer
PRINTS TEST PAGE WHEN TURNED ON
MY 1315 PRINTS A TEST PAGE EACH TIME I TURN IT ON, HOW CAN I TURN THAT FEATURE OFF?
Actually its not my solution... see http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447627+1235819514435+28353475&threadId=932709
"Holly" posted something that worked for me:
Holly Jul 6, 2005 07:09:59 GMT Unassigned Hello!
This is something you can try. Sometimes the printer doesn't understand that the alignment page you are scanning is for it to read, therefore you have to do a 'standalone alignment' on the unit before it actually does understand. Here is how you do it:
1. Hold Cancel and On, then release.
2. In sequence, press Cancel, Resume, Paper Type, Color Start Copy.
3. Another alignment page will print out and this is the one that you should actually put faced down in the scanner glass and press Scan.
^Hopefully that will be the last and final time that the alignment page prints out!!
Posted on Feb 28, 2009
My hp c3150 prints a test page every time i turn it on
Do this. The next time it prints a test page, keep the same test page under the scanner and push the scan button on the c3150. This would complete the test cycle and it would not print test pages from the next time.
Nov 17, 2009 | HP PSC 1315 All-In-One InkJet Printer
Prints a self test page everytime
Replace ALL ink cartidges with NEW HP cartridges.
Jun 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 Prints test page every time printer is installed
Hi Jay,
This is mike, actually the problem is that that printer has not completed the aligning process, as a result the printer is printing the test page (Alignment page) every time when you turn it ON. So, I would suggest you to let the printer prints the alignment page and check whether the printer prints the page with all colors and it printed fine, once it is done, disconnect the USB cable behind the printer and then place the alignment page on the scanner glass by facing down the printed page downwards and press the scan button. This start the alignment process and the scanning process will be completed once the ON light is stop blinking. This will complete the alignment process.
Once done try to turn off and turn on the printer and check for the result. This should resolve the issue.
However, if the issue persist, then please revert back to me. Be sure that you use the HP genuine ink cartridges, not refilled nor re-manufacture.
Jun 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
My printer keeps printing the test page every time it's switched on
Unplug the printer and leave it for three minutes and then plug it back in. This will reboot it and it may cure the problem.
Feb 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
Test printing
If you've recently changed your cartridges, the printer will try to print a test/alignment page. Note the instructions on the test page indicate what to do to complete the testing/alignment procedure.
1) Let it print.
2) Place the test page upside down on the scan plate.
3) Hit "Scan" and let it finish.
When the machine completes the scanning procedure, you'll be able to switch the printer on and off or reboot your computer without it printing the test page. By Dubbya
Sep 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP psc1317 printer - wasting paper on power on by printing test paper
If the alignment is not done sucessfully then the printer prints a test page every time the printer is turned on, so it is recommended to align the printer and the cartridge.
Try th steps again in the bellow link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00109818&dlc=en&product=374568
Good Luck
Aug 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
Test Page
Go to the printer settings through the software given by HP, probably HP solution centre and choose printer settings and further you can go deep to disable the test page at startup.
Thankyou
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Prints test page every time the printer is turned on
This might be an alignment page. To get it to stop, you will have to go through the alignment and new cartrige setup in the hp software. This should be located under Start/All Programs/HP folder. I'm not sure what the software would be called but it should be easy to do if you have the HP software installed. Hope this helps!
Nov 07, 2007 | HP PSC 1315 All-In-One InkJet Printer
After changed cartrige, every time I turn on the printer,it always prints the test page.
I would first contact Stylus website view the troubleshooting remarks. I probable says to uninstall the software dirty disk or 15 other things its a process of elimination like humm? how things could keep a car from starting.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
121 people viewed this question
Ben Johnson
