Question about JVC Audio Players & Recorders
Belt needed for L-AX3 turntable by JVC. - JVC Audio Players & Recorders
    New Friend:
  • 27 Answers
LPgear.com has many parts that are no longer in production.
as well as hard to find parts.
Posted on Feb 27, 2009
Auto adjust
You could have got the Belt in the wrong position. If correct try looking underneath the turntable for small presets. They might be hidden or covered up. If you can't see them you will have to take off the bottom and look on the PC board for them.
Apr 27, 2013 | JVC Audio Players & Recorders
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
How to replace the belt on jvc l-f130 turntable
You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
Nov 22, 2009 | JVC AL A158BK Turntable
WEAK SOUND WHEN CONNECTED TO DURABRAND AMP
The electrical output from a turntable actually comes from the cartridge on the tone arm. Specifically, it's generated by an interaction between a magnet and a coil inside the cartridge. They come in two types, MC ("moving coil") and MM ("moving magnet") according to which of the two elements moves and which is fixed. MM cartridges produce more current but MC cartridges usually sound better. No matter which you have though, the total output is too low for the regular line inputs on amplifiers. Ten or twenty years ago, amps has special "phono" inputs. This would have a special pre-amplifier in it that would amplify the cartridge's singal to a level suitable for the rest of the amp. Most amps having a phono input only deal with MM cartridges, which have a higher signal.
I use an MC cartridge with an amp that doesn't have a phono input at all; therefore I needed to buy a special external phono pre-amp. I bought a Musical Fidelity X-LPS. But cheaper pre-amps do exist.
Apr 13, 2009 | Audio Players & Recorders
Jvc turntable
hi, please check first your fuse inside your turntable, replace it if possible
Apr 04, 2009 | JVC AL A158BK Turntable
How do you reinstall drive belt for JVC AL A155 model turntable?
http://www.archive.org/details/Turntable_Belt_Installation
archive.org above has a video about how to do it. The general method shown applies to just about any turntable including your JVC
Feb 10, 2009 | JVC AL A158BK Turntable
JVC turntable LA10
The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
Hope that helps.
Mar 16, 2008 | Audio Players & Recorders
How to replace belt in jvc turntable
I just got a JVC turntable from a thrift shop today and as soon as I got it home the belt broke. I had a replacement but couldn't figure out how to install it. After taking off the back, which is about 4 screws plus the 4 feet and the grounding screw, I saw a very tiny set screw on the post where the spindle obviously is. I removed this and the table came right off so I could replace the belt. I couldn't get the tiny set screw back but figured I didn't need it and if I ever have to replace another belt, I won't have to take the back off anyway. I hope this helps.
Jan 02, 2008 | Audio Players & Recorders
194 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
